Old 09-16-2009, 09:57 AM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
72 jimmy top
Will any other years fit the 72 jimmy top?? I am sure that 67-72 are the same but what about newer years?
vance
VanceH is offline   Reply With Quote
Old 09-16-2009, 10:29 AM   #2
vtblazer
vtblazer's Avatar
Re: 72 jimmy top
No such thing as a 67 or 68 top, first year for blazers/Jimmies is 1969.
A 69-72 top will fit all years but there's also two version's of hard tops.
They made a double walled top 69 thru 71 but had a single walled top as an option in 71 and OEM in 72.
vtblazer is offline   Reply With Quote
Old 09-16-2009, 11:07 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 72 jimmy top
Actually, the first year for the Jimmy was 1970.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-16-2009, 11:14 AM   #4
vtblazer
vtblazer's Avatar
Re: 72 jimmy top
Yep, my bad.
Old 09-16-2009, 12:20 PM   #5
VanceH
Loving the Jimmster
VanceH's Avatar
Re: 72 jimmy top
So they made a blazer in 69 and a jimmy in 70? also you say oem top on a 72 is single walled, but mine has a double top, does that mean its not oem?? By the way thanks for all info, there is much to learn!!!!!!!!!!!!
Old 09-16-2009, 04:16 PM   #6
71jimmy
71jimmy's Avatar
Re: 72 jimmy top
I believe the single wall top was an option starting in '72. I've not come across a single wall on a '71 that was original. just my .02.
'73 through '75 tops will not work.
Look at the SPID on your glove box door. It should tell you what top yours had from factory. From reading all the wonderfull posts through the years it seems that some '72s had only double wall holes, some only had single wall holes, and some had both holes for single and doulble wall tops. Go figure.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-16-2009, 09:34 PM   #7
old man jimmy
Re: 72 jimmy top
Sorry but their was no single or double wall option. Just hard or soft. When they changed from double to single in 72. They used up all their left over double wall tops first. So if you have a double wall on a 72, good chance it was made early in the model year. Like mine.
old man jimmy is offline   Reply With Quote
Old 09-17-2009, 12:54 AM   #8
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: 72 jimmy top
Mine has single wall but has holes for both. does have plug for dome lights so I believe it came from factory with single since double wall has no dome lights.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 09-17-2009, 03:54 PM   #9
bouncytruck
SKINNY TIRES RULE!
Re: 72 jimmy top
This is what I have always heard too. AFAIK, softtops were dealer options and wouldn't be listed on the SPID.
Here's my SPID
bouncytruck 1972 K5
