TH350-C transmission, opinions please.
I found out today that I have a TH350-C transmission. I know that they have a lockup torque converter. Can I get some opinions on this type of transmission so that I can decide what do about the one I have. Thanks.
laying low
![]() Join Date: Mar 2001
Re: TH350-C transmission, opinions please.
With the lockup converter it is almost like an overdrive tranny in that it reduces the engine rpm when locked up thereby increasing fuel mileage. This tranny requires the electric/vacumn solenoid and brake lamp switch to make the lockup feature work correctly. However some guys take a cheaper route and wire in a toggle switch to manually lock/unlock the converter. You must remember to unlock it every time you come to a stop or it can kill the engine.
A local tranny shop told me I shouldn't run that trans without the lockup hooked up and working as it will kill the trans in short order. Could be a liability thing. It is in my truck but has not been on the road yet. Palf70step has one in his truck. Maybe he can answer some of your ?s
![]() ![]() Join Date: Jul 2002
Like Boog, mine is not yet on the road. I was told by my tranny guy you could run them without the lock up option, but you would have more slippage off the line, like a hi stall converter, but without the power. Yes it will kill it eventually and before it' time, but I have know a few folks to drive them for years without the lockup connected.
MY $.02, if you have the choice go with a 2004R for the overdrive, or just use the normal T350. It will be a bit stouter unit. Had mine not already been rebuilt, I would have used the T350 I recently acquired instead.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 09-17-2009 at 10:45 PM. |
laying low
Oh hey Bill. I knew you were right around the corner.
Thanks fellas. I'm not sure if the guy before me had it hooked up.I would really like to go with a th350. I probably will. Then it becomes pick and choose with some other stuff for my truck.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I was broke one time and needed a trans so I bought a used TH350C from a junkyard. Obviously, it was used when I got it and I ran it 4 years without ever hooking up the lockup. I put about 75k miles on it like that. I never saw any signs I was hurting it in that time by running it unhooked.
