Old 09-15-2009, 08:54 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
700R4 Trans
Do any of you guys have a 700R4 trans in your truck? If so what kind of tranny crossmember did you use?
Laid_Out_50 is offline   Reply With Quote
Old 09-15-2009, 09:09 PM   #2
sn33kyp3t3
sn33kyp3t3's Avatar
Re: 700R4 Trans
I'm running a 700r4, don't have the x-member yet, but will go with Chassis Engineering Inc.'s. I like their price, and have heard good things about their service/products.
http://chassisengineeringinc.com/page11.html
$67.75
sn33kyp3t3 is offline   Reply With Quote
Old 09-15-2009, 09:25 PM   #3
Laid_Out_50
Re: 700R4 Trans
$67.75
Did you have to modify the floor in your cab to run the 700
Old 09-15-2009, 09:41 PM   #4
pgf545
pgf545's Avatar
Re: 700R4 Trans
I out a 700R4 in my dad's...I don't think you will need to modify the floor, but we went with a aftermarket kit. I used a tubular cross member from Progressive. Take a look at my build thread towards the last few pages.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 09-15-2009, 09:53 PM   #5
sn33kyp3t3
sn33kyp3t3's Avatar
Re: 700R4 Trans
You don't need to mod the floor. I've heard of guys mounting the engine/trans higher in their trucks to allow clearance for the steering components (less u-joints etc) in which case you would need to mod the floor.
Old 09-15-2009, 09:54 PM   #6
nebdrummer
nebdrummer's Avatar
Re: 700R4 Trans
we didnt have to do anything cab wise to make the trans fit. were using a 77 el camino subframe and it sits everything nice and deep down in there.
crossmember was just a basic bolt in universal trans crossmember from brothers.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 09-16-2009, 08:47 AM   #7
robin58
Re: 700R4 Trans
Brother's has a similar crossmember on sale at $46.99
http://www.brotherstrucks.com/products.asp?dept=520
robin58 is offline   Reply With Quote
Old 09-16-2009, 11:44 AM   #8
mylow53
mylow53's Avatar
Re: 700R4 Trans
i have the brothers on mine and it's pretty simple to install.
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 09-16-2009, 08:50 PM   #9
nebdrummer
nebdrummer's Avatar
Re: 700R4 Trans
yep, same one.
Old 09-17-2009, 05:55 PM   #10
Cyrus
Cyrus's Avatar
Re: 700R4 Trans
I was looking at the Brother's one myself. Is it really just a "bolt in" or did you have to modífy it? How's the pinion angle?
My build thread (so far):http://67-72chevytrucks.com/vboard/s...d.php?t=360258
1958 GMC PM152 270 I6 4-speed
1994 GMC Sonoma 2WD TBI 5.0 700R4
Cyrus is offline   Reply With Quote
Old 09-17-2009, 07:04 PM   #11
mylow53
mylow53's Avatar
Re: 700R4 Trans
Originally Posted by Cyrus View Post
I was looking at the Brother's one myself. Is it really just a "bolt in" or did you have to modify it? How's the pinion angle?
it bolts in fine. i chosed to weld in the ends so nothing was banging around... no modifications required. some times pinion angle or off set will help your ujoints last longer. Chrysler off set their engines so the ujoint needle bearings orbited the case....
GT
Greg
Old 09-18-2009, 08:50 AM   #12
robin58
Re: 700R4 Trans
Unless they've changed their design since I got mine, the center tube part is separate from the two ends so it adapts to your set pinion angle. You fit it as needed bolting the brackets to the frame, tackweld the tube to the sleeve on the brackets in the position needed, remove and weld the whole thing.
