Old 09-19-2009, 01:10 PM   #1
Dr_Spankenstein
Dr_Spankenstein's Avatar
Exclamation alternator conversion
hey all
I have a '61 with a '87 350 in it, with I think a '73ish water pump.
I had the original generator in there it just died so I was going to swap out the alternator and regulator from my '66 will this work ok?
also my generator is on the drivers side and I am having a problem finding brackets for that side. any suggestions?
thanks
Dr_Spankenstein is offline   Reply With Quote
Old 09-19-2009, 01:15 PM   #2
Dr_Spankenstein
Re: alternator conversion
http://cgi.ebay.com/ebaymotors/NEW-S...824168003r5441
maybe this will work?
Old 09-19-2009, 02:16 PM   #3
Eagar1
that would only work if you don't have power steering, I believe it takes that spot. I personally dont like to hang accessories low as it makes them harder to get to. You need to find the brackets for a factory style set up, that looks like this:
Eagar1 is offline   Reply With Quote
Old 09-19-2009, 02:19 PM   #4
Eagar1
Hit the wrong button
Old 09-19-2009, 02:52 PM   #5
Dr_Spankenstein
cool thanks for the reply
I got it in with a combo of parts from both trucks in the stock location.
now I have a stupid question: the round capciter looking thing on the regulator (forgot what is called) where does it hook to. I know it physicaly mounts to the fire wall but where does the wire hook to?
Old 09-19-2009, 03:19 PM   #6
Eagar1
Not sure I know what you are talking about, got a picture?
Old 09-19-2009, 03:52 PM   #7
Dr_Spankenstein
no I don't have a pic. I just looked at my bros '66 and he doesn't have it so maybe it is not necessary?
the problem I am having is the alt light (dash) is on, and when I disconnect the bat truck dies
there are three wire coming off the generator (black, green{f}, brown{A}) the alt harness has red(bat) yellow(R) green(F)
I think I am just going to buy a new alt and do the upgrade correctly. thanks for your help though
Old 09-19-2009, 08:47 PM   #8
DPowers
One foot in front of the other
DPowers's Avatar
Check this out
http://www.persh.org/pickup/IdeaPage.htm
DPowers is offline   Reply With Quote
Old 09-20-2009, 07:52 PM   #9
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Converting to an internally regulated alternator is easy as can be and takes no time at all.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
