Old 09-20-2009, 09:49 PM   #726
joe231
joe231's Avatar
Re: Glock's new project: "Fred"
dude you flat busted ass on this thing...i'm super impressed
for making such a killer truck!!
tell the kids...the next LS swap, they have to do it, you can just over-see the work as the shop foreman
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-20-2009, 10:16 PM   #727
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Looks Good!
Everything you did was top notch!
When you catch your breath,... I'd be interested in purcha$ing a step by step install guide from you.
Make plenty of copies,... I'm not the only one.
Congrats, again.
Thanks a lot man!! I'll probably be taking my time writing it up. I've been thinking of breaking it down in to sections; electrical, exhaust, fuel system, mounts, trans, etc.
Originally Posted by menace121978 View Post
Fred looks awesome with that front end! nice job man. i had to watch that video again too.
It's too bad there are so many GMC tags on him, because I really like the Chevy grill too! And I'll admit, I've watched it a bunch of times too!
Thanks Joe!!! Just under one month total, I'm pretty surprised myself. And I don't think my son would mind that at all!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-20-2009, 11:20 PM   #728
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by 68 TT View Post
I was a machinist in the Air Force for 13 years and worked at the flight test center repairing and building test aircraft parts & equipment and have made & redesigned many things like that over the years. There are a couple minor things you may want to fix if you are going to make a new one.
Where the small metric male threads transition to the hex stock put a 1/4" fillet radius there. It will increase the strength of the part tremendously.
It doesn't need to be that long either. Less length will put less load on the threads if you accidentally lean against it while working on the truck. It would suck to snap that thing off flush with the head. The closer you can get the sensor to the head the better.
If you can make it out of brass or aluminum bronze that would be much better too.
The stainless will need antisieze compound on it to keep from galling the threads and getting stuck in the head plus the galvanic corrosion from the dissimilar metals will cause the aluminum head to oxidize around the fitting possibly causing it to leak down the road.
Aluminum bronze or brass will only need Teflon tape as they are much closer to aluminum in the dissimilar metals range chart.
You could make it out of round stock and just put a set of wrenching flats on it to use more common scrap material.
I really don't think we can put a .25 radius in the corner. If I'm not mistaken the seal is made on the face of the metric end. Also, I think the length needs to be pretty close to what he purchased because the length of the original sender has to fit inside. I like the idea of using brass. I had thought about the dissimilarity of the metals too. It may cause corrosion in the future.
Bob,
Great progress! You have that puppy just about ready to roll! congrats I know you have some serious time invested.
Old 09-21-2009, 06:28 AM   #729
nlped
nlped's Avatar
Congratulations!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-21-2009, 07:44 AM   #730
silvereagle07
silvereagle07's Avatar
Congradulations! It looks and sounds great. I like the updated front end too.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 09-21-2009, 09:40 AM   #731
JohnC
JohnC's Avatar
Man it looks, and sounds amazing. I love the chevy grill, and truth be told I bet many people won't catch that it has a bowtie on the grill, and GMC everywhere else. to you and your helpers man.
JohnC is offline   Reply With Quote
Old 09-21-2009, 09:53 AM   #732
glock35ipsc
Thanks John!!
I just called a yard in Loveland, and they have a throttle module! So I am heading there right after work to get it. HOPEFULLY that is the problem!
Bob
Old 09-21-2009, 10:20 AM   #733
JohnC
JohnC's Avatar
Fingers crossed man!
Old 09-21-2009, 10:31 AM   #734
glock35ipsc
I like this! Regular GMC grill with a 4mm billet insert.
Bob
Old 09-21-2009, 10:38 AM   #735
menace121978
menace121978's Avatar
X2 on the fingers crossed!
^^^^ thats the same grille i put on my '85 blaze... i loved it!! looks cleaner and meaner than the chevy grille. i think you have found the winner!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-21-2009, 10:40 AM   #736
JohnC
JohnC's Avatar
That looks good, but to me it's just hard to beat the Chevrolet version. Just my .02
Old 09-21-2009, 01:12 PM   #737
glock35ipsc
I gotta agree with ya John, but I don't really want to change all the GMC badging over to Chebby right now. $$$$! I am still thinking I will do it when it is time to paint him though. I'll probably just run a driver quality GMC grill for now.
On another note, my wonderful wife is on her way to Loveland and pick up the module for me. And I have just enough left to run to Autozone on the way home and get a fairly decent code reader.
Bob
Old 09-21-2009, 01:15 PM   #738
menace121978
"Dennis the Menace"
Old 09-21-2009, 01:52 PM   #739
Oilbrnr
Oilbrnr's Avatar
Wow, I'm glad I stumbled on this build thread! I've had a 2007 4.8l sitting in my garage now for about a year that I want to put in my K5. Now that things are cooling down in my shop, I think the time has come. Not to mention the fact that the Goodwrench 350 is drinking a quart of oil every fillup.
One of my challenges will be flywheel/clutch combo to work with a SM465.
Great work and good info! Anxiously awaiting the write-up with part #'s etc!!!
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 09-21-2009, 04:52 PM   #740
nlped
nlped's Avatar
I like that Grille!!! That's what I plan to do to "Bob"
Carter
Old 09-21-2009, 09:17 PM   #741
glock35ipsc
Grrrrr, TAC module didn't fix it. It's also giving me 2 codes for the sensor on the pedal. If I get really lucky, the refund from the fuel hose I sent back will be in my account in the morning and I can get one ordered from Rock Auto.
Bob
Old 09-22-2009, 08:49 AM   #742
rongstad
Future: 86 on GenIV power!
Are you sticking to the same color?
rongstad is offline   Reply With Quote
Old 09-22-2009, 09:27 AM   #743
glock35ipsc
Kind of. It will still be red-ish, but I'm thinking it will be darker. Maybe much darker. Maybe darker to the point that it almost matches the carmine red interior.
Well, the news is so-so this morning. The refund did indeed show up n my checking account this morning, so I have the APP sensor on order from Rock Auto already via 2nd day express.
However, when I ran in to the shop this morning to grab my glasses off the tool box, there was a small puddle of antifreeze under the area of the right rear cylinder head. I think the S&P adapter is leaking. Didn't have time to check, but I'll bet that's it.
So, I'll wait for the APP sensor to get here on Thursday and give that a try. I was careful to remove it from the pedal before I started cutting and welding on it so I wouldn't damage it, but I guess it was either damaged before or...... eh, who knows.
Oh, I was also getting codes for the rear O2 sensor heater circuits, so I might have to send my PCM back to make sure they removed the rear O2 programming.
Bob
Old 09-22-2009, 11:34 AM   #744
JohnC
JohnC's Avatar
Hope that's all the snags. Keep us updated.
Old 09-22-2009, 11:55 AM   #745
menace121978
bummer to hear the adaptor is leaking and the sensor trouble Bob. you'll get it!! and good luck!!
btw, darker red sounds sweet... i'm planning on a beautiful color called red jewel found on the tbss's. you should check it out. there's so many different shades of red out there... the new metallic red on the titans is amazing too.
"Dennis the Menace"
Old 09-22-2009, 12:23 PM   #746
68 TT
Still plays with trucks
68 TT's Avatar
With a connection cable and a converter box with your laptop you can read and reset the codes with some free software. I did it with my 03 Tahoe and it helped me diagnose an intake leak.
http://www.scantool.net/obdlink-ci.html
Costs $65 plus shipping.
68 TT is offline   Reply With Quote
Old 09-22-2009, 03:03 PM   #747
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Bob, that is the set up I want to run on mine too, just need $$. We need to take some pictures of Fred and The Toybox together. Maybe I will just come out one of these days and give you a hand with anything needed. Good work so far man!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-22-2009, 04:17 PM   #748
glock35ipsc
I got an email from mcbassin today that he has already shipped out the new replacement temp sensor adapter!! That guy rocks! Yeah, sooooo many reds to choose from!
Plus $500 for a laptop, makes my scanner much cheaper! My laptop died a long time ago.
I've got some great spots for pics! Come out anytime!
BTW, this is the scanner I got. It's nothing like my old Snap-on MT2500, but it'll work for my needs. Plus I can just leave it behind the seat.
Bob
Old 09-22-2009, 05:40 PM   #749
Mine is in the drawer, but I think I have the exact same model scanner/code reader. It works on all the vehicles I have except the 70 ( I wonder why ). It has been very useful, even to tell the Kia dealer things about the wife's car before it goes into service.
Old 09-22-2009, 05:59 PM   #750
joe231
joe231's Avatar
what did that scanner cost ya?
CHEVY ONLY
