Old 09-21-2009, 05:22 PM   #1
jlolson
jlolson's Avatar
Emissions fail - any advice
I've failed emissions twice on my '71 C20 5.7L.
Prior to first test:
Vehicle was not running when I bought it. Fresh oil/filter, new plug wires, new gas tank, flushed fuel lines, new carburetor, timing adjusted, idle screw adjusted but left idle fuel mixture screws alone (new Edelbrock carb, thought it would be dialed in).
Pollutant: Reading/Standard - Result
Loaded Hydrocarbons (HC) in PPM: 132/450 - PASS
Loaded Carbon Monoxide (CO) in %: 3.54/3.75 - PASS
Idle Hydrocarbons (HC) in PPM: 379/450 - PASS
Idle Carbon Monoxide (CO) in %: 8.94/5.0 - FAIL
Prior to second test:
Idle fuel mixture screws dialed down as low as possible without stalling, Idle set precisely 550RPM in drive, replaced PCV valve, new spark plugs, burned one can of "guaranteed to pass" emissions formula, filled up with 91 octane, added 1 can of octane booster, drove for about 20 minutes on the freeway to get it hot as hell prior to testing.
Loaded Hydrocarbons (HC) in PPM: 149/450 - PASS
Loaded Carbon Monoxide (CO) in %: 5.68/3.75 - FAIL
Idle Hydrocarbons (HC) in PPM: 119/450 - PASS
Idle Carbon Monoxide (CO) in %: 1.88/5.0 - PASS
I'm going to give this one last try prior to taking it to a shop. I may have screwed up the "guaranteed to pass" emissions formula by not running the tank completely empty (looked empty but when I filled up it only took 15G). I'm going to run it empty again and put more fresh high octane. I also plan on changing the oil again, the engine was likely all sludgey after sitting for 4 years and 2 oil changes won't hurt.
I'd really appreciate any suggestions because I'm out of ideas. I've already spent a small fortune on this thing and can't get it licensed. I really don't need to start dealing with a mechanic on this truck, I bought it so I could do the work myself. Any tips/tricks/repairs before I go again???????
jlolson is offline   Reply With Quote
Old 09-21-2009, 05:33 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Emissions fail - any advice
You went the wrong way. Excessive carbon monoxide indicates a LEAN mixture, not fat. So you were running lean at idle on the first test and OK in the midrange. On the 2nd test, you got the idle mixture right, but something affected the midrange and caused you to run lean under a load.
Excessive Hydrocarbons indicate a fat mixture. Edelbrocks typically run leaner than Holley's from my experience. Richen it up, and possibly jet it up one size if possible and you may pass. Also, try running some marvel mystery oil through the gas and oil per the bottle's recommendations. Not sure if that will work, but if it's been sitting for a while, I think it's supposed to clean things out.
69GMCLonghorn is offline   Reply With Quote
Old 09-21-2009, 05:38 PM   #3
jlolson
jlolson's Avatar
I leaned it up with the IFM due to the Test#1 fail for idle CO. For test #2 idle CO was much better but the loaded CO jumped up and failed. Is this a case of finding a happy medium? Test #2 results indicate I can move the IFM screws back out a little. BUT, I thought the IFM and Idle screw only impact the way the carb runs at idle and really had nothing to do with air/fuel mixture when you step on the gas. Am I wrong?
Old 09-21-2009, 05:45 PM   #4
truckster
truckster's Avatar
I've had success in the past running my old carbureted Subaru with denatured alcohol in the tank. I ran it down to about 5 gallons of gas and added a gallon of denatured. I had to boost up the idle speed a little bit to get it to idle smoothly. The tech at the I/M station said, "I don't know what you did, but you sure cleaned this thing up."
truckster is offline   Reply With Quote
Old 09-21-2009, 05:50 PM   #5
69GMCLonghorn
My feeling is you have something funky (beyond adjustment) going on with that carb. What is wrong, I don't know, but everything shouldn't have changed according to what you just said. If you go to certain smog shops, sometimes they can run the truck on the dyno without actually running a test to make sure it will pass or not. If it's a fix-it shop, they can adjust the carb until it passes (or until they find the problem).
Old 09-21-2009, 06:00 PM   #6
vectorit
What?
vectorit's Avatar
Wow, AZ requires you to smog your 1971 truck. I had to look it up, and sure enough you guys have to smog everything from 1967 on up.
Here in CA where I thought just about every law was out of whack, CA exempts everything pre 1975 huh.
If I were you, and others will prolly scoff at this. But I'd find a good 1971 Q-jet and temporarily swap out the Edlebrock, since IIRC those carbs aren't smog legal anyway. So you may be wasting your time? I'd dunno, just throwin it out there.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-21-2009, 06:07 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Try running 87 octane fuel instead. When I had to take emissions tests in the past this helped. I have had several smog techs tell me this too.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-21-2009, 06:08 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Pre-76
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-21-2009, 06:14 PM   #9
mclairmo
When CA still required smog checks on my 67 Camaro, I took it to many smog testers till I found a Korean guy that just passed it, no questions asked even though I had no smog equipment and all aftermarket stuff. I also knew a guy that merely needed the VIN and $200 and could get it passed. My buddy found another smog guy that played his carb until it passed and then put it back to where it would actually run right.
mclairmo is offline   Reply With Quote
Old 09-21-2009, 06:21 PM   #10
leddzepp
Moderator
leddzepp's Avatar
That was before a 50K fine was imposed on illegal smog checks. You won't find anyone doing this anymore, unless they don't care about their livlihood. I used to give my neighbor $50 and the VIN to my old truck. It passed smog and never even left my driveway
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-21-2009, 06:23 PM   #11
vectorit
What?
vectorit's Avatar
I just read one of your other posts, and in it you say you are running headers?
If this is true, here in CA they would fail you on just the visual.
If your state allows this, then you need to take into account for those headers while figuring out your A/F settings.
In that other post, you also mentioned you are using an HEI with 7mm plug wires that are melting on the headers. Bad ignition will affect your smog test also, since you are probably arching on the header pipes from the melted wires.
I'm no expert at emmsions testing, but these I think would be pretty important issues to address.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-21-2009, 06:39 PM   #12
john
member #16
john's Avatar
Back when mine was still under smog rules I had them check the emissions before the test, Then if an adjustnent was needed it was done before the actual test.
john is offline   Reply With Quote
Old 09-21-2009, 06:53 PM   #13
big_al_71
big_al_71's Avatar
Here in Florida they tried that smog testing and of course it did not last but maybe a couple of years because the samething happened just slip the guy a $50.00 and you passed. They finally realized that there were too many crooked employess and shut it down completely....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-21-2009, 06:55 PM   #14
coloradosean2009
coloradosean2009's Avatar
Lean mixture will lower CO. not the other way around.
The mixture screws on an edlebrock only change the idle mixture. The difference between the two under load measurments would indicate a testing error (assuming that nothing else changed).
Grounded spark causing a miss will lift the hydrocarbon count. I don't think that is it.
Bring your idle mix up a little. Get your idle around 850.
Test again. In Colorado, the retests are free. Once I told the guy to retest three times in a row. It passed on the third without any adjustments. I think that the test probe is not the most accurate.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 09-21-2009, 07:19 PM   #15
mclairmo
The good ol days.
Old 09-21-2009, 07:27 PM   #16
texanidiot25
Eat My Rust
texanidiot25's Avatar
Move to Texas. As long as your lights all flash and your horn goes beep, it passes.
texanidiot25 is offline   Reply With Quote
Old 09-21-2009, 07:56 PM   #17
jlolson
jlolson's Avatar
My horn doesn't beep either
Old 09-21-2009, 08:56 PM   #18
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
+1 on low octane. The lower the octane you'll have complete fuel burn and will eliminate any problems.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 09-21-2009, 09:04 PM   #19
msgross
msgross's Avatar
you need to move to Indiana... no inspections at all!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-21-2009, 10:37 PM   #20
crm318
Alright Alright Alright
crm318's Avatar
Yeah, in Texas, it 14.00 dollars (blinkers, horn, tail lights, and wipers all work) and youre on your way. Its a restorers dream.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 09-21-2009, 10:40 PM   #21
texanidiot25
Eat My Rust
And you have to have muffled tail pipes 'past the doors' is the basic rule of thumb, but if you find a cool shop they can even let that slide I'd wager.
Old 09-21-2009, 10:46 PM   #22
QKENUF4U
QKENUF4U's Avatar
NO OCTANE boost or high octane gas.....that screwed ya right there.... OCTANE SLOWS THE BURN !!!... anyways get a can of acetone, dump in gas tank, set mixture screws correctly (turn in till stumbles/idles rough then turn out 1/2-1 turn) set idle at 1000-1500rpm.... make sure its at operating temp when ya get there and dont idle in line.... (ex phoenix resident just went thru getting my 91 to pass)
QKENUF4U is offline   Reply With Quote
Old 09-21-2009, 10:50 PM   #23
truckdude239
truckdude239's Avatar
IN GREAT OLD NC any vehicle 35 years or older does not have to pass any kind fo inspection
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-21-2009, 11:51 PM   #24
vegaschevy
There are huge fines here and you can still find $100 smog checks EVERYWHERE!!!! 100 bucks is a TOIN of money to someone making 7 bucks an hour.
I have been going to the same place and many people for years!
vegaschevy is offline   Reply With Quote
Old 09-21-2009, 11:53 PM   #25
dwcsr
Hollister Road Co.
dwcsr's Avatar
They inspected my 59 from accross the parking lot, never even went in the bay.
