Closed Thread
Old 09-20-2009, 03:21 PM   #226
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
These are my measurements from the two rotors:
1" ROTORS:
-Hub Diameter: 2.650"
-Hub height: 1.750"
-Total height from wheel flange to end of dust cover: 2-11/16"
-Height from disc face to lugnut flange: 1-7/8"
1.25" ROTORS:
-Hub Diameter: 2.895"
-Hub height: 2"
-Total height from wheel flange to end of dust cover: N/A (No cap on my rotor)
-Height from disc face to lugnut flange: 1-9/16"
Looks like the thinner rotor has a taller "hat",... and a shorter hub.
And here's the wheel mounted!
Keith
Convert to disc brakes.
lolife99 is offline
Old 09-20-2009, 03:40 PM   #227
lolife99
lolife99's Avatar
Here's the final dimensions.
(excuse my crappy skills in "paint")
Keith
lolife99 is offline
Old 09-20-2009, 04:37 PM   #228
71'tahoe
71'tahoe's Avatar
Nice!! Now I got to figure how to get them to work on my 97' truck!!
71'tahoe is offline
Old 09-20-2009, 05:42 PM   #229
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Nice work Keith.
78 Build Thread
4Runner Build
smashingchuck is offline
Old 09-20-2009, 06:46 PM   #230
lolife99
lolife99's Avatar
This won't solve everyones issues,... but at least they will fit something.
And,... I don't have to return mine or wait for the new design.
Keith
lolife99 is offline
Old 09-20-2009, 08:18 PM   #231
djracer
djracer's Avatar
I hope I don't have these issues on a mustang II rotor. I bought these in a 18x8 and a 18x9.5 for my brothers 59 truck. We have the rears on and haven't done the fronts yet.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline
Old 09-21-2009, 09:33 AM   #232
71'tahoe
71'tahoe's Avatar
I did some digging and ithink the 88-98 trucks are like the 73-87 trucks they used 2 different rotors depending on the option or the gvwr. i may head to the parts store and pull a few rotors and measure..
71'tahoe is offline
Old 09-21-2009, 02:17 PM   #233
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome FAQ Keith!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline
Old 09-21-2009, 02:46 PM   #234
Hart_Rod
Hart_Rod's Avatar
Keith - quick questions, I'm getting ready to buy new spindles and am thinking about going with the LD ones. What else has to be changed besides the rotors and spindles to make the LD stuff work? Thanks,
R/
Hart_Rod is offline
Old 09-21-2009, 04:54 PM   #235
Benji_1802
Thumbs up Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Great feed back man...i got the 20x8 & 20x10 set up for my 72 c10, so i only need to get the 1" thick rotors? or will i need the drop spindles for 1" brake rotors as well? will caliper from my stock 1.25 rotors work on the 1" rotors? any feedback will help. Thanks.
Benji_1802 is offline
Old 09-21-2009, 06:08 PM   #236
lolife99
lolife99's Avatar
Rob and Benji,... the only thing I'm not sure about is the calipers.
I need to stop by the local auto parts store and check that out tomorrow,... but I'm sure they are a different part number.
If I had DSL,... I'd look online,... but it's not worth the effort. (And the slow internet, driving me crazy)
My frame is a 1983,... so that's the application I will use.
(Hint, hint dsl guys)
Last night I ordered a set of 73-87 Belltech 3" drop spindles (part #3200 for the LD version), for my '86 Dropmember project.
Anyone else running 63-70 conversion spindles will have to swap to the 73-87 version and change balljoints.
I think the upper and lower balljoints of the 71-72 trucks will work with the 73-87 spindles,... but I'm not 100% sure.
(another cross reference item for you dsl guys)
I'm pretty sure there is no 1" spindle for the pre '73 trucks,... so a balljoint/tie rod switch will be in order.
(with maybe the exception being the 71-72 trucks)
Keith
lolife99 is offline
Old 09-22-2009, 05:37 AM   #237
mentlmidget
GUYS! please remember that going to a 20" wheel combo is going to be double, if not triple the weight per wheel. Braking distance IS INCREASED. Before ordering all the brake hardware, think about increasing the rotor diameter, which would also include a different caliper/spindle setup. I am all for the GO GO GO, but we also need to STOP STOP STOP.
I didn't think there was going to be that much of a difference from the 15" 165/50/15 combo I had until I went out to do this measuring. Holy cow was that wheel heavy. I am a school teacher who used to work at a few tire shops in my younger years. I equal the weight to about a split rim set up for a box truck. Maybe not quite that bad, but heavy enough.
I AM looking into getting a bigger brake combo for my rig.
Just keep the longer stopping distance in mind.
mentlmidget is offline
Old 09-22-2009, 05:48 AM   #238
lolife99
lolife99's Avatar
Good luck finding a rotor,... ANY rotor,... that will fit this wheel.
So far the Light Duty version of the stock rotor is the ONLY one that will work.
And that's what you have right now.
Let me know if you find another rotor/brake system that this wheel will fit.
Keith
lolife99 is offline
Old 09-22-2009, 07:37 AM   #239
brossow
Amateur Rust Fighter
brossow's Avatar
Let's not get into a panic here. Do you upgrade your brakes if you're going to have a passenger in your vehicle? Didn't think so. The rims weigh more, but the tires weigh less. And we're talking about a 2-ton vehicle, not a 500-pound motorcycle. Yes, there's a difference in rotational mass, but overall the weight difference is negligible in the big scheme of things on a vehicle this size. (If you want to do the math, an increase in rotational mass equates to about a 10x increase in static mass -- for example, adding 40 lbs at the wheels is roughly the same as adding 400 lbs of cargo.) If your braking system is so close to its limits that the weight of the wheels means life or death, you've got bigger problems than wheel selection.
I agree that brakes need to be a MUCH higher priority than just about anything else on a vehicle. But I don't see adding a few pounds per corner as something that necessitates a $2000 brake upgrade. IMHO, of course.
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 09-22-2009, 08:26 AM   #240
vegaschevy
Brent
I laugh when people make this argument. Like when they pull that 2 ton trailer, or load the bed that the truck was okd to haul. or when you put the 5 passengers in the vehicle. better upgrade your brakes ASAP
vegaschevy is offline
Old 09-22-2009, 12:07 PM   #241
lolife99
lolife99's Avatar
I'm good with a brake upgrade,... but until they redesign this wheel,... they won't fit anything except the factory LD rotors.
I guess I was just happy to get them to bolt on with no modifications,... finally.
You guys keep me posted if you find another rotor that will work,... or a new part number for the redesigned wheel.
Keith
lolife99 is offline
Old 09-22-2009, 03:13 PM   #242
mentlmidget
I am not panicing, nor am I suggesting there be a panic. I am only stating, since I have put the 20's on my truck, my stopping distance has increased. I wouldn't consider myself a maniac on the road, but then again, this is subjective.
Old 09-22-2009, 03:18 PM   #243
brossow
brossow's Avatar
Yup, and that's an expected occurrence -- same as if your fat cousin Cheeto is along for the ride. Something to be aware of when you're driving around getting used to the new wheels, but not something that should necessitate a brake system upgrade.
Brent
brossow is offline
Old 09-23-2009, 09:34 AM   #244
DrtyJack75
well I was just looking at the ECE page and the brake conversion they sell (and I bought) have a 1.25" rotor.
So is it possible to just go back to the 1" or is there something to do with the newer spindles that you have to have the 1.25" (or heavy duty)?
DrtyJack75 is offline
Old 09-23-2009, 10:41 AM   #245
SCOTI
SCOTI's Avatar
You can machine the HD 1.25" rotors & use spacers to work w/these wheels if you can accommodate the slight increase of track width.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 09-23-2009, 10:59 AM   #246
DrtyJack75
Id rather not use spacers? Sorry if I missed it but is there any word on the release of the new wheels?
Old 09-23-2009, 11:57 AM   #247
lolife99
lolife99's Avatar
The only way to use the 73-87 1" LD rotor is to change ball joints and outer tie rod ends.
Your ECE "conversion spindle" eliminates all that.
It may be better to wait for the "new" design on the wheel itself.
Keith
lolife99 is offline
Old 09-23-2009, 11:58 AM   #248
lolife99
lolife99's Avatar
I haven't heard anything yet.
Keith
lolife99 is offline
Old 09-23-2009, 04:36 PM   #249
nlped
nlped's Avatar
I haven't heard anything good, just "it should be soon".
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 09-23-2009, 11:23 PM   #250
DrtyJack75
I talked to Jeff from ECE today and he had another option but I dont think it's worth it..
He said I can take my spindles off they can press out my PIN (Axle) and he can press in the smaller one that accomidates the standard rotor...
to much work if you ask me..
So Ill just wait for the wheels to come out..
hey NLPD, How was it you can tell the new design? I thought you said soemthing about part # or something.
THANKS!!
Closed Thread
