09-20-2009, 08:42 PM | #1 |
64 chevrolet truck
i got this truck is seat on blazer frame i like to swap to a diferent frame any good sugestions thanks Last edited by pepe_38; 09-20-2009 at 08:51 PM. |
09-20-2009, 08:58 PM | #2 |
Re: 64 chevrolet truck
Yea ........ since you live in Ga. I've got a 65 frame for you ????
09-21-2009, 04:22 PM | #3 |
well i like to keep on 5 bolt pattern how much you take for you frame and wat comes w/ the frame thanks
09-22-2009, 12:47 AM | #4 |
60-66 Nut
So that Blazer frame is a 2wd correct?
09-22-2009, 03:44 PM | #5 |
yes 2 wheel drive but i don like ride that high
09-23-2009, 12:07 AM | #6 |
60-66 Nut
Yes that is how these trucks end up when put the body on a '73-'87 2wd frame, unless the body is channeled. Which is a lot of work.
If you can get that frame from 198Plus. Then put the front suspension and rear differential on that new frame. That way you'll have the correct style frame with a good ride height and your 5 lug wheel bolt pattern. It'll be some work, but well worth it in the end.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-23-2009 at 12:08 AM. |
09-23-2009, 03:58 PM | #7 |
thanks
