09-21-2009, 05:29 PM | #1 |
Broken Down
Heater Motor ??
I have a 80 C10 with a/c when i turn the ignition to the run position I hear the fan running. The heater/air condition controls are in the off position. When I turn the key off naturally the fan stops. Do I have a bad blower resistor, or bad control, or is there something else??
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
09-21-2009, 11:10 PM | #2 |
Re: Heater Motor ??
Yo! Chevy designed the fan to run on low, at anytime the key is on, for ventilation. I rigged mine with a toggle to turn it off. Nothing wrong with your truck.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
09-21-2009, 11:43 PM | #3 |
Re: Heater Motor ??
I cut the yellow wire at the blower motor resistor on my '80 (I saw the tip on here).
no more low, but I don't need no stinking low.....the silence is golden
CHEVY ONLY |
09-23-2009, 05:17 PM | #4 |
Broken Down
Re: Heater Motor ??
Thank you for the info... Next question. Why does my a/c compressor kick on when I have it on defrost mode???
09-23-2009, 05:35 PM | #5 |
Re: Heater Motor ??
Most all do.
A/C takes the moisture out of the air, so it is benefical when you use the defroster, it also helps de-fog
CHEVY ONLY |
09-23-2009, 05:50 PM | #6 |
Broken Down
Re: Heater Motor ??
Thanks for the information!!! Much appreciated.
