Old 09-23-2009, 08:55 PM   #1
blklblsk8tr13
blklblsk8tr13's Avatar
Straightening bent axles?
my back right tire sits crooked. its not the bearings so i think the axle tubing is bent. can it be straightened? its a dana 44. i would just replace it but i have lift blocks welded to the axle and i dont know if they can just be torched off. help?
blklblsk8tr13 is offline   Reply With Quote
Old 09-23-2009, 09:32 PM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Straightening bent axles?
you can always convert to 3/4 ton or even 1 ton????
depends on how their welded to the axle. you way be axle to get a grinder and grind the welds till you can persuade it to come off with a big hammer
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-23-2009, 09:58 PM   #3
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Have you spun the rear wheel to make sure the axle shaft itself isn’t bent? It takes a good whack to bend an actual housing axle tube to the point where it changes the toe setting. If that indeed happened, you will be better off swapping in a different rear axle assembly.
DirtyLarry is offline   Reply With Quote
Old 09-23-2009, 10:03 PM   #4
^^^^ x2 ^^^^
Blocks are cheap.
Old 09-23-2009, 11:22 PM   #5
jrdv
jrdv's Avatar
I bent the housing on my blazer about 20 years ago.
I broke the axle and it came out while I was trying to get the blazer out of other peoples way. I replaced the axle and didn't think about the housing being bent. After replacing the axle seal twice--Duh! I had to put another rearend in.
A new rearend would be the easiest fix for you.
Otherwise, check this site out.
http://www.crankshaftcoalition.com/w...ar_end_housing
jrdv is offline   Reply With Quote
Old 09-23-2009, 11:56 PM   #6
blklblsk8tr13
^^^^ x2 ^^^^
Blocks are cheap.
they are 8'' lift blocks. is there a possibility that i could cut them off and use them on the new axle?
Old 09-24-2009, 06:28 AM   #7
yeah,I would think you could cut/grind them off.Maybe cut the saddles from the housing then cut/grind/clean them off the block.You`re trashing the housing anyway.
Old 09-24-2009, 08:28 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
[QUOTE=blklblsk8tr13;3534952]they are 8'' lift blocks. [QUOTE]
8" lift blocks That sounds scary.
Do you get a lot of wheel hop?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-24-2009, 05:47 PM   #9
I had the same thought and meant to warn there`d be a reaction over that.
Old 09-24-2009, 08:26 PM   #10
LONGHAIR
Personally I would throw the 8" blocks away with the bent housing.....they are both bad.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-28-2009, 11:23 PM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Oh boy, 8" blocks? And on the front axle! Hurry and get 8" springs.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-29-2009, 06:55 AM   #12
Hmmm...I didn`t get that.I though we were talking about the rear end.
Old 09-29-2009, 07:12 PM   #13
Eichorst69
Is this dana 44 in the REAR of a full size truck??????
I'd look for a 14 bolt with new springs and down size or eleminate your blocks all together.
Eichorst69 is offline   Reply With Quote
Old 09-29-2009, 11:12 PM   #14
bigbadchev72
People know me
bigbadchev72's Avatar
He said his right REAR tire sits crooked
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 09-29-2009, 11:35 PM   #15
2tons of fun
chevy used the 44 rears in 4x4 from 60-66ish.
its a 44, its got 8" blocks, its wasted.
2tons of fun is offline   Reply With Quote
Old 09-30-2009, 07:13 AM   #16
A Dana44 rear is every bit as good as a 12-bolt.That`s not the problem.It takes alot to bend any housing...alot!
Old 10-04-2009, 10:40 PM   #17
blklblsk8tr13
theres a problem with all this "replacement" talk. im 18 and spent my life savings on this truck. i am broke. hahaha my theory is ill wait till it breaks to replace things. how many psi should i run in my swampers?
Old 10-04-2009, 11:00 PM   #18
shilo
shilo's Avatar
what size are your swamps? I run 10 psi in mine. And i should be running lower, maybe 8. i have bead locks though. However on my old K30 with 44's and no bead lock 16.5" rim i ran 10 to 12 psi with those and had no problems. Swamps like to be low
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 10-04-2009, 11:18 PM   #19
skchevota
skchevota's Avatar
8" blocks, welded to the housing, does not sound good!!!! But on the plus side, yes you can straighten housings to a point. If they are bent in one spot, it can be done, if it is a s bend then no. many years ago my uncle built a 70 nova drag car witha 9" rear, inorder to have the slicks under the car he narowed the axle housing. Unfortunatly he did not use a jig, and the axle housing was a little off when done. He pulled it apart and took it to a shop that narrows axles. They put it in a hydraulic bender,press kind if thing and straightend it right out.
In your case, you need to see if the labor of tearing down the axle, finding a shop with the said machine , paying them, and then a reasembley is worth the $$$ compaired to just replacing the whole thing. I would say replace and upgrade, you can find a used axle in the wrecking yard for a couple hundered. Once metle is bent, and then bent back, that will be a week spot that will bend easier than the first time.
some frame shops can do a half arss
sraighten if you can see where it is bent. They will put a stand under the axle where it is bent and chain the rest down, them push or pull on the end or the axle to bring it close to where it needs to be. If you fin a shop with an alighment rack as well they can do this with the alighment heads on the wheels so they can tell when the camber and toe are where they need to be. This also would mean that you would not have to take it all apart. The success of this methed would depend on the shop used , there experiance doing this, and how badly it is bent. If you take it to a frame shop and ask them, they should beable to take a free look and see if they can do anything.
I would try this first if you are on a tight budget.
skchevota is offline   Reply With Quote
Old 10-05-2009, 12:43 AM   #20
Husker
Husker's Avatar
I had a slightly bent axle in My Jeep. I used a chunk of chain and a Bottle jack and something to keep the chain from slipping off of the jack end. I used a piece of square tubing and slid over the end of the jack. Wrap the chain around the side that is bent out from the pumpkin and the other end close to the center unless both tubes are bent then wrap both ends away from the center(pumpkin) stick the jack between the center and the chain and jack till it straightens. You probaly should wear some gloves and some saftey glasses. It will slowly pull it back straight or close to it.
You may want to reinforce with a truss or something so it does not bend again. I used a Piece of round pipe over the top of the Pumpkin bent down to each tube.
Hope this makes sense
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-06-2009, 07:42 PM   #21
msgross
msgross's Avatar
you can probably find another axle for very cheap... then i'd spend money on new springs if you want that much lift... or this might be a perfect time to downsize because it sounds like it's built to big for 1/2 ton axles anyway...
someone will trade you tires, rims and springs I bet.. Then you would have a better driving, safer truck as well.
heck, I sold a 12 bolt for $50 and my next option was 5 cents per pound at the scrap yard.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
axle, bent, dana 44, straighten
