Old 09-25-2009, 11:24 AM   #801
menace121978
menace121978's Avatar
Re: Glock's new project: "Fred"
thats going to trip them out!! people tend to act a little different when your on a phone 16 hours away compared to right in front of them w/ a dont screw with me face on!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-25-2009, 11:24 AM   #802
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Originally Posted by 68 TT View Post
I can get truck rear ends for $85 complete at the pull it yourself yard with a 30 day warranty or pay $300 at the main yard and get a six month warranty.
I'll give you $250 to pull one and bring it to me then!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-25-2009, 11:27 AM   #803
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by mcbassin View Post
Bob,
Sorry to hear about all of your pedal issues. I hope you get that sorted out quick. I also hope one of those brass parts will work for you. Amazing how much better they look in the picture. Good luck!
Mike
They turned out great. Good job.
Now that you have them figured out and better than the other product you should make a stash and offer them for sale.
Maybe make a version with 1/4-NPT threads in place of the 12 mm for people with stripped out heads.
68 TT is offline   Reply With Quote
Old 09-25-2009, 11:33 AM   #804
glock35ipsc
Hmmmm, he doesn't know what I look like....... knowadImean?
Bob
Old 09-25-2009, 11:37 AM   #805
68 TT
68 TT's Avatar
Truck freight couldn't be that much on 200 pounds from WA to CO.
I could get you the carrier & gears and ship those to you if you can't get what you want locally for a decent price. Probably be $80 after shipping cost.
That goes for anybody else too. Just let me know what gear you are looking for and I will see what they have on hand.
Old 09-25-2009, 11:47 AM   #806
glock35ipsc
I have gears for my rear end, but it's a complete 88-98 rear that I want. Freight on a complete rearend (200#, Class 85) with my freight discount is $112. So not really that much better than what I can get here. Appreciate the offer though!
Bob
Old 09-25-2009, 02:58 PM   #807
JohnC
JohnC's Avatar
So is the advantage of the 88-98 rear end just the added track width, or is there any other benefit?
JohnC is offline   Reply With Quote
Old 09-25-2009, 03:06 PM   #808
rongstad
Future: 86 on GenIV power!
X 2.......I was wondering the same thing
rongstad is offline   Reply With Quote
Old 09-25-2009, 03:18 PM   #809
glock35ipsc
That's pretty much the reason I am looking for one from that era.
One other added benefit you might count is that it is likely to have less miles on it than another 73-87 donor rear end.
Bob
Old 09-25-2009, 03:24 PM   #810
JohnC
JohnC's Avatar
How easy is it to mount under a 73-87 truck? I know nlped had some issues when he put his under the truck and was lowering it.
Old 09-25-2009, 03:30 PM   #811
glock35ipsc
Well, Dennis paid a visit to my salesman at Rancho! It seems as though the salesman got a lesson in what customer service should be all about, and how it stretches beyond state lines. I think he also now understands how word of mouth can reach potential customers who live only minutes away from your business, even if the mouth is over a thousand miles away in another state!
Oh how I would have LOVED to have been a fly on the wall this afternoon! Dennis, THANKS BROTHER!!
BTW, I just got an email from him saying the pedal, harness and module should ship today. And I quote: " I apologise for the poor service (as stated by the fellow that was here this morning) We will try to do better. "
Bob
Old 09-25-2009, 03:36 PM   #812
glock35ipsc
Have welder, will swap!
It involves removing the spring perches and shock mounts from the original and welding them on to the replacement. Of course, care needs to be taken to install the perches in the right location and making sure the pinion angle is correct. Same with making sure the shock brackets are in the right location. E-brake stuff should swap over, and I am not sure on brake lines. The 88-98 might be metric, but the 73-87 wheel cylinders might also swap over. Or I suppose the entire backing plate couple be swapped.
If I remember correctly, Ed's issue was the diameter of the 88-98 housing is larger in diameter, so a typical 73-87 flip kit won't fit. But if you do this swap and do the flip at the same time, simply weld the perches on the bottom of the housing instead of the top.
Bob
Old 09-25-2009, 04:25 PM   #813
glock35ipsc
Oh, I forgot to add..... I picked up the pedal and harness from the dealership around 11:30 this morning. Hopefully by about 17:30 I'll know if I am going cruising on Sunday or not!
Bob
Old 09-25-2009, 04:34 PM   #814
nlped
nlped's Avatar
^^^Yeah that was my only issue with the rearend. The primary brake line on the newer rearend from the frame to the housing works with the factory fitting up top. I used the larger '96 rear brakes without issue. The added width really made the factory ralley's look more even front to rear, and the new 18x9.5" wheels look GREAT with the added track width...if they will just finish the damn new version so I can have my fronts. The other primary advantage to the '88-'98 rearend is that it is 30 spline rather than 28 spline and there are more posi applications available for the 30 spline ones.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-25-2009, 05:21 PM   #815
Oilbrnr
Oilbrnr's Avatar
Classic!!!
Internet to the rescue!
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 09-25-2009, 07:43 PM   #816
glock35ipsc
IT FREAKIN WORKS!!!!!!!!!!!!!!!!!!!!!
Bob
Old 09-25-2009, 07:50 PM   #817
Oilbrnr
Oilbrnr's Avatar
Congrats!!!
Uh, documentation please.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-25-2009, 07:56 PM   #818
joe231
joe231's Avatar
Right on!!!!!!!!!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-25-2009, 08:51 PM   #819
hessian18
Gen III Power
hessian18's Avatar
Way to GO BOB !!!!
Im so happy for you ahahah
+1 for the PDF how too ....Im in line
Video or ban ?
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 09-25-2009, 08:56 PM   #820
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Awesome! I read this entire thread today and have anxiously been awaiting the update!
I have a '87 that has been in the family a LONG time. It has a fairly weak TBI 305, and is ready for a repower. I was just about to build a mild TBI 350 roller motor to replace the 305. I was having a hard time getting excited about the TBI 350. I now KNOW what I'm going to do! Thanks for all of the great pictures and valuable information. I will start a bulid thread when I get the ball rolling.
I deleted the pics here and added them to the "pictures" post.
Mr.Chevy4x4 is offline   Reply With Quote
Old 09-25-2009, 08:57 PM   #821
Mr.Chevy4x4
I guess I would be called a lurker! Look at my join date and number of posts!
Old 09-25-2009, 11:02 PM   #822
Alright!!!!!!!
Old 09-25-2009, 11:07 PM   #823
glock35ipsc
Good news!!!! And a little bad....
First, the bad. The flipping heater core is leaking now!! So I have that half way out. And the thermostat is stuck. I have a LOT heat in the block and the heater hoses, but the lower radiator hose is cold less than 2" away from the water neck. The top hose is cold.
So tomorrow I get to go buy a heater core and a thermostat. I hate doing heater cores, cause I hate antifreeze!
Otherwise, I did get to drive it up and down the driveway a couple time. It's gravel, so I didn't get on it, but I can tell it's gonna be really responsive!
Bob
Old 09-25-2009, 11:13 PM   #824
Even11
PICS (Video?) OR IT DIDN'T HAPPEN!!
Congrats though!! Put me in line for the how-to manual too!
-Dane
Even11 is offline   Reply With Quote
Old 09-26-2009, 12:06 AM   #825
menace121978
AWESOME!! RIGHT ON BOB!!! i dont know how to make my words big so i used caps!
thats great news he runs with throttle control...
i bet your taking out the thermostat, poking holes in it, by passing the heater core and out driving right now After all it is Friday night!! man, i'm glad you got him done. i took a 1/2 hour lunch just so i could get home and check the results...
and btw, just glad i could help and be of service. It was good talking to you today Bob we'll meet one day soon!! Feel free to use that number anytime buddy.
i'm glad they sent an email at least apologizing and trying to make it right even if "sorry" doesnt cover lost time and money.
"Dennis the Menace"
