Old 09-26-2009, 02:02 PM   #1
neiloneil
neiloneil's Avatar
gas questions
was curious what type of gas most use in their older trucks...any one use lead additives since the Ethanol Fuel has been introduced?
neiloneil is offline   Reply With Quote
Old 09-26-2009, 02:41 PM   #2
Martin64
Martin64's Avatar
Re: gas questions
I just use regular unleaded.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 09-26-2009, 09:30 PM   #3
Eagar1
Re: gas questions
The only reason gas had lead in it was to lube the valves and maybe raise the octane level a bit. There are additives available to replace the lead that you have to pour in with each tank. Most engines have had their valves redone due to valve recession, and have had hardened seats installed so they can use any of the unleaded fuels. You can just use the regular unleaded unless you have an original classic you arent going to drive much that still has the original heads on it.
Eagar1 is offline   Reply With Quote
Old 09-26-2009, 09:39 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: gas questions
Agree with Eagar1 - the other additive which works well on older original engines is Marvel Mystery Oil. It specifically lubricates the valves when mixed in the gas. My dad, neighbor and many of the old timers I grew up around all used this stuff in all their cars, by installing a Marvel Inverse Oiler. It was an automated drip feed that lubricated the upper cylinders in reverse proportion to engine vacuum. They still work great and can be found on Ebay once in a while. What did them in was the catalytic converter, which outlawed additives of this kind.
Old 09-27-2009, 01:40 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: gas questions
i use premium unleaded in my 66. Don't HAVE to but i like having the extra protection against detonation. If your motor is even a remotely modern rebuild, it will have the hardened valve seats for unleaded gas.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-27-2009, 12:59 PM   #6
neiloneil
neiloneil's Avatar
Re: gas questions
i thought the lead also brings the boiling point up which would help with vapor lock
