Old 09-26-2009, 12:32 PM   #1
Conundrum
Conundrum's Avatar
IFS question
My dad has a 48 GMC panel truck that he has had for the past 34 years, he is finally going to get started on it and is wanting to change it over to IFS.
I told him I would get on here and ask to see what companies you guys would recomend. He would like to get one that uses some of the factory holes to locate it, or one equally as simple to install. Most companies have options like manual or power steering, coil springs or bags, so I won't get into that for now.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 09-26-2009, 03:51 PM   #2
stevehsd
stevehsd's Avatar
Re: IFS question
Heidts
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 09-26-2009, 04:13 PM   #3
wigadore
wigadore's Avatar
Re: IFS question
I purchased a TCI (Total Cost Involved) Mustang II IFS from http://www.streetrodparts.tv and it was easy to install.
wigadore is offline   Reply With Quote
Old 09-26-2009, 06:10 PM   #4
GRIMSS
GRIMSS's Avatar
Re: IFS question
Scotts Hot Rods.
http://www.scottshotrods.com/frontends.asp
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 09-27-2009, 12:30 PM   #5
Conundrum
Conundrum's Avatar
Re: IFS question
Thanks for the input, I will let my dad know. I will also try and post some pics when the project gets started. Thanks again.
Old 09-28-2009, 11:04 AM   #6
Laid_Out_50
Laid_Out_50's Avatar
Re: IFS question
Jim Weimer hotrods same as all the others but half the price
Laid_Out_50 is offline   Reply With Quote
Old 09-29-2009, 12:00 AM   #7
Scottshotrods
Re: IFS question
Please explain to us at Scotts Hotrods how the Jim Weimer is the same ifs
as ours.
Justin
Scotts Hotods
Scottshotrods is offline   Reply With Quote
Old 09-29-2009, 08:10 AM   #8
Laid_Out_50
Re: IFS question
all of these weld in IFS kits for these trucks are based off the same design. "There is nothing different that you can do to make yours better than a JW, Heidts or a Fatman kit
Old 09-29-2009, 08:39 AM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: IFS question
2X Scotts
Justin made a 1 off air ride for a 35 international one ton he went out of his way alot of back and forth emails and pics when it was done the fit was perfect...I have bought a bunch of Mis. part threw them..and there customer service is second to none...my first call is always to them
thanx Justin
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-29-2009, 05:25 PM   #10
GRIMSS
GRIMSS's Avatar
Re: IFS question
Originally Posted by Hottrucks View Post
2X Scotts
thanx Justin
Jeff
I second that. None of that off the shelf stuff here. Custom made to what I wanted to do with my truck.
I want to see pics of that international Jeff.
2001 GMC SIERRA
1968 Camaro
Jared
Old 09-29-2009, 07:03 PM   #11
Hottrucks
Hottrucks's Avatar
Re: IFS question
sorry dude it gone...I run them a year or so then mov on after I get about 5000 miles or so on them..but I think my truck now is here for a very long time
Old 09-29-2009, 07:20 PM   #12
Scottshotrods
Re: IFS question
Not hardly.
All "OTHER" IFS systems are built and based off of Mustang II systems or other existing suspension components; that is how they can keep parts on the shelf. If they all take the same a-arm, they can make a hundred or so.
Every one of our IFS units are built to spec and per application. They are "based" on nothing. They are Designed, jigs built, a-arms made, and cross-members made, per order and per application.
On our shelves we have zero a-arms built, no cross-members laying around, and only pre-machined lengths of A-arm tube ready to make.
This is not a knock on anyones front-end, this is simply how we do it and how we do offer something that is 100% different than anything else out there. Don't let the looks fool you, a few degrees, inches, angles, difference can make or brake the front end.
Besides, who besides us offers a lifetime warranty
Old 09-29-2009, 09:15 PM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: IFS question
Justin
All aftermarket IFS is based of something. From what I see yours is a Hybrid MII where the JW IFS is complete MII so its like compairing apples to oranges. What spindle do you use? Is it MII or Impala or some other design?
I have never liked the top hat on a MII design and have never installed one for that reason. I do like the way you set the top of yours up with easy adjustments for alignment. What the weight limit on yours?
Old 09-30-2009, 01:27 AM   #14
Scottshotrods
Re: IFS question
Originally Posted by dwcsr View Post
Justin
Not to argue a point here.....but to argue a point, this is simply not true.
What do you consider "based off of" to be? Do I use a Mustang II Spindle? yes in most cases. Is it the only spindle I use? No it's not.
The only thing our ifs sytems are "based off of" is a certain geometry we look to achieve based on the type of car/truck, weight, ride height, or handling characteristics the customer is looking to achieve. Once the numbers are plugged in starting from the wheelbase, frame dimension, and ride height, the 12 pivot points are programmed in to where they need to be, then the jig is made, and the ifs is built to those exact specifications.
let me put this in simpler terms.
If the CEO of GM decided to build a one off car to race on the salt flats, and had an unlimited amount of resources, he would not grab any Corvette/Camaro/truck suspension and stick it under that car. His designers would build him a front end that achieved EXACTLY what he was looking for.
Actually for the Mustang II that front end was perfect. Again, it was designed for THAT CAR.
I honestly could not tell you what the weight limit is on our systems. I mean if I had to guess I would say it maxes out at whatever the most commercially available spindle/brake combination would be. Maybe something off of a 2-ton truck (which we have done btw)
Old 09-30-2009, 01:53 AM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: IFS question
That was the answer I was looking for I just didn't form the question properly. So you actually build the IFS to meet a specific requirement on a per customer basis rather than a cookie cutter kit like most MII kits.
Old 09-30-2009, 10:41 AM   #16
Hottrucks
Hottrucks's Avatar
Re: IFS question
Is that like saying your chevy truck is based off a FORD truck??? I mean they both have wheels and a bed???...just kidding...and by the way when I get back tonight I hope to post a pic of that 2 ton air ride Justin is talking about... the pics are on the old puter...
Jeff
