Old 09-28-2009, 11:01 PM   #901
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Glock's new project: "Fred"
Great pic Kevin!!
You're right Gerald, hardly phased him at all. He's more bummed that he can't go ATV'ing with his Grandpa next Saturday than anything else.
On another note, I got a $25 Shell gas card in the mail today. I cashed in some debit card rewards points. And since I bought the engine and most everything else for this swap on my debit card, I should have some KILLER points built up next time around!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-28-2009, 11:03 PM   #902
joe231
joe231's Avatar
Echo....echo...echo....echo
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-28-2009, 11:11 PM   #903
glock35ipsc
Um, oops!!! Fixed that.
Bob
Old 09-28-2009, 11:22 PM   #904
joe231
joe231's Avatar
I think there was a glitch in the Matrix....I almost had one too...then the server was too busy...growing pains are good
CHEVY ONLY
Old 09-28-2009, 11:38 PM   #905
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Show off! "Hi I'm Bob and I'm a moderator."
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-28-2009, 11:46 PM   #906
menace121978
menace121978's Avatar
look who talking about being a show off with that new flashing avatar!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-28-2009, 11:48 PM   #907
glock35ipsc
Show off! "Hi, I'm Gerald, and I have a flash-bling avatar too!"
Bob
Old 09-29-2009, 12:00 AM   #908
menace121978
"Dennis the Menace"
Old 09-29-2009, 12:02 AM   #909
Driveway Dreams
I have car A.D.D.
Thanks for that one Bob. I like it alot.
Dennis, post again...you are at 999.
-Gerald
Old 09-29-2009, 12:12 AM   #910
menace121978
couldnt help it... i had to post in the sept. gtg thread about your guys roads out there! that was # 1000!!
"Dennis the Menace"
Old 09-29-2009, 09:04 AM   #911
JohnC
JohnC's Avatar
You guys are cracking me up.
JohnC is offline   Reply With Quote
Old 09-29-2009, 09:16 AM   #912
nlped
nlped's Avatar
PM sent!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-29-2009, 09:24 AM   #913
glock35ipsc
Got it Ed, thanks! It'll be on it's way tomorrow.
Bob
Old 09-29-2009, 11:33 AM   #914
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by menace121978 View Post
just enough for a new set of tires!!!
Just enough for two sticky rear tires
68 TT is offline   Reply With Quote
Old 09-30-2009, 10:19 AM   #915
glock35ipsc
Not much for updates, except that I've been driving the snot out of this thang! I haven't quite reached the half-tank mark on the second tank of fuel through it yet. Only problem I've noticed so far is that the passenger side pump only puts out 50-51 psi at idle, and only 1 psi more at cruise. There have been no performance issues, and the truck runs the same on either tank (58 psi on the drivers's tank), so I'm not worrying too much about it right now. I do need to look at the data to see if it's running lean, that's all I can think would happen.
Oh, one good thing.... Going to go pick up a rear end tomorrow! Bought a dry 3.42 rear from a 91 C1500 with good brakes for $200. So that will be this weekends project. THAT'S going to be awesome!! Not only will the speedo work correctly now, but I will be able to experience all of the 5.3's power, and the mpg should go up a little.
I was comparing tire size and gearing to the 03 I use to have. My 03 had 255/70-16 tires and 3.73's. It got 19-20 on the highway consistently, even with the blower. My gearing chart shows that combo turning 2250 rpm's at 77 mph.
With Fred's 275/60-15 tires and the 3.42's, it should turn 2250 rpm's at 78 mph. Almost identical!
Add to the fact that Fred weighs just over 1000# lighter than my 03, and I think the mid 20's are do-able. I'm already seeing 20-21.
Bob
Old 09-30-2009, 10:40 AM   #916
menace121978
hows' the boy?
"Dennis the Menace"
Old 09-30-2009, 10:48 AM   #917
JohnC
JohnC's Avatar
That's awesome Bob. Not only did you make the entire swap look like a cake walk, but now you are going to gloat your great mpg in front of us too?
Old 09-30-2009, 10:54 AM   #918
rongstad
Future: 86 on GenIV power!
Where did you put the fuel pressure gauge? which tank selector switch valve did you buy?
rongstad is offline   Reply With Quote
Old 09-30-2009, 11:03 AM   #919
nlped
nlped's Avatar
That's awesome!!!
Carter
Old 09-30-2009, 11:03 AM   #920
glock35ipsc
hows' the boy?
He's doing awesome, thanks for asking!! He's such a good kid, he hasn't complained once. Then again, he is the center of attention right now, and he's a lady's man at school......
If I don't, what was the point??
The sensor for the gauge is on the fuel rail, and I used a Pollak high pressure switching valve.
Bob
Old 09-30-2009, 11:12 AM   #921
JohnC
JohnC's Avatar
A wise guy eh?
Old 09-30-2009, 11:45 AM   #922
68 TT
68 TT's Avatar
Thanks a lot. I get 8 mpg and see 3850 rpm at 70 mph with my 5.13 gears and 32" tall tires.
If I only had 28" tall tires like you I would be at 4300 rpm at 70 mph. Can you say 5 mpg?
Yes, overdrive is in my near future.
Old 09-30-2009, 11:49 AM   #923
glock35ipsc
Or a 6 speed?
Bob
Old 09-30-2009, 02:16 PM   #924
nlped
nlped's Avatar
Okay Bob, now get on with the E85 stuff and the A/C stuff. It's been nearly 6 days since you got the truck up and running. What is the hold up?
Carter
Old 09-30-2009, 02:26 PM   #925
glock35ipsc
I've been too busy driving it!!!
I did get an 88-98 rear end bought, did you miss that? That will be going in this weekend.
Bob
