need help with vin
i just aquired a 67-72 gmc with vin CE134-ZZ54133. the vin decoder on this site does not have the right codes to match the vin
![]() Last edited by jcueckert13; 04-08-2003 at 07:40 PM. |
#2 | |
Bloo
try www.gmcpauls.com ,GMC vins are different from chevy
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
thanks for the link the part i need is still under conctruction though
1990 subaru legcy (daily driver) 1987 Toyota 4runner (weekend toy) 1968 ![]() 1970 ![]() 1976 Dodge Dart 1963 Dodge Dart ![]() |
#4 | |
Bloo
CE134-ZZ54133
i'll see what i can do for ya then C-2wd E-V8 1-1/2 ton 34- body code and wheelbase i think ZZ- not sure, must be a GMC thing? i think its the plant it was made at and the year it was built... the first Z should be the year, and i think the second would be the fremont plant.. 54133- sequintal model number i think that should be it, im guessing by using GMC 67-9 model data and 67-72 Chevy vin data
![]() Last edited by Blue_71; 04-08-2003 at 08:43 PM. |
thanks for the help. my father lost the title
![]() Join Date: May 2002
Here is what i came up with:
C = 2wd E = V8 1 = 1/2 ton - 3600-5600# 34 = body code (ie pickup, panel, suburban) Z = Flint (production plant) Z = year (either 70, 71, or 72) 54133 = sequential model that rolled off the plant line
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Here's what my decoder says:
C - Conventional Cab 4x2 E - V8 Gasoline engine 1 - 1500 Series (1/2 ton) 34 - Pickup / Wideside Z - Assembly Plant (Flint?) Z - 1970 54133 - Production Sequence Number
'68 GMC 1500 LWB Fleetside w/350 & 3 spd (for now) |
thank you for the help. the info from dat matchs up with the exception of the bed but i dont konw what is original and what is not. thank you again
Some of you got close... any way the first Z is for Fremont assembly plant and the second Z is for 1970. 34 is for wideside/fletside type box. 34 is a GMC thing.
With the vin like this its a 70 GMC 1/2 ton V8 fleetside/wideside box. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
