Old 10-01-2009, 11:29 AM   #1
CB24
how low can you lower these trucks....
How low can you lower your truck & still be able to use it as a truck? I want to lower my truck but I also want to be able to haul things in the bed from time to time. Is it something where you have to pick one or the other or can you have a little of both worlds? I have a 69' 1/2 LWB if that makes any difference.
CB24 is offline   Reply With Quote
Old 10-01-2009, 12:46 PM   #2
WCRiot
Re: how low can you lower these trucks....
Buy some 3in lowering blocks for $60 and that will handle the rear
WCRiot is offline   Reply With Quote
Old 10-01-2009, 01:05 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
depends if you go static drop or air ride. and it will also depend on the total weight of the load, if you have auxillary springs, if your frame is notched.....
there are many combinations.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-01-2009, 01:38 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Check www.earlyclassic.com website. They have pix of customers trucks. Used to be one on there that had a "substantial" load in the bed of it, i.e., it was used like it they wanted to use it, in spite of the lowering. I have a 2.5/4 drop on mine and it hauled what I wanted to .....but it's disassembled for a re-do.
Member Nr. 2770
Old 10-01-2009, 01:41 PM   #5
CB24
Cool I'll check that out. Thanks!
Old 10-01-2009, 01:49 PM   #6
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
bag it,slam it, and drive it
it's sitting on the shocks here and with the new shocks it dropped about another 1/1.5 inches....it will lay header pipes and the X will be about 1.5 inch off the ground
Hottrucks is offline   Reply With Quote
Old 10-01-2009, 02:43 PM   #7
CB24
The only problem with bagging it is it takes up bed space.
Old 10-01-2009, 03:37 PM   #8
SCOTI
SCOTI's Avatar
Depending on how it's done & how low you want it to go.
I had rear bags on my 68 & everything was mounted under the bed floor. It used every last mm of the bolt-in c-notch if air'd out but could still pull an 18ft car trailer loaded w/another swb truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-01-2009, 06:24 PM   #9
Hottrucks
Hottrucks's Avatar
NOT 1 INCH and it's not expecive I could bag a truck for under ( $70 per bag plus a little line) $300 with a notch
less if you can find some used bags
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 10-02-2009, 08:14 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
im 4" - 6" static and still haul a quad and tow a boat no problem. imo occasionally hitting the bumpstops isnt a problem. fronts sit on bumpstops, less body roll.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-02-2009, 08:17 PM   #11
Wasted Income
Boosted Member
Wasted Income's Avatar
x2 for bag it and use it as a truck still. I didn't lose any bed space, either.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-03-2009, 01:04 AM   #12
DZL1
One day.....
DZL1's Avatar
Same as Wasted Income. Can still use as truck without losing bed space and still be LOW!
DZL1.
DZL1 is offline   Reply With Quote
Old 10-03-2009, 09:51 AM   #13
Hottrucks
Hottrucks's Avatar
hey DZL1 what did you do to your panard bar?? I just cut mine and about and added3/4" to it
Old 10-03-2009, 10:42 AM   #14
2tons of fun
ill be bagging mine but not lowering it much. im doing it for ride quality, to air dump it when its parked, and load handeling.
with the gauge set and a split front rear system you pump the back up to handle any load cap that the bag will.
2tons of fun is offline   Reply With Quote
Old 10-03-2009, 12:41 PM   #15
DZL1
One day.....
DZL1's Avatar
Hottrucks, I have an adjustable panhard bar from CPP.
DZL1.
Old 10-03-2009, 12:58 PM   #16
Hottrucks
Hottrucks's Avatar
kool what size rear tires?? are those 8's or 10's?? I just put 265/70/15's on the back and I hate it!!! I want more rubber back there?? do yours rub??
Old 10-03-2009, 01:22 PM   #17
DZL1
One day.....
DZL1's Avatar
My wheels are by 8". I'm runnuing 235/70/15 no rubbing. Hope this helps.
DZL1.
