Old 10-01-2009, 08:57 PM   #1
big10ratrod77
big10ratrod77's Avatar
one bad squeek
yea my rat rod is being a turd for the last weeks it squeeks it sounds like its from the rear end on the driver side it squeeks through each gear but not between gears and only when accelerating, dont squeek when coasting, and i had it on the lift at school today and ran through the gears and it didnt squeek and i dont like it what could be some things i could check
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 10-01-2009, 09:51 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: one bad squeek
sure it aint a u joint?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-01-2009, 10:23 PM   #3
f.monroe
f.monroe's Avatar
Re: one bad squeek
U joint , rear U joint but might as well replace them both if it is a one piece drive shaft .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-01-2009, 10:27 PM   #4
71swb4x4
71swb4x4's Avatar
Re: one bad squeek
If it's a rat rod doesn't that just add to the character?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-02-2009, 12:22 AM   #5
Storm Chaser
Storm Chaser's Avatar
Re: one bad squeek
I 3rd the U-joint. Could be pinion bearings or something further into the rearend (pray for U-joint). I had an S-10 once that squeeked like you describe, and it was actually the leaf springs- changed those plastic things between the leaf and the squeek went away... but I'm betting that's not common.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 10-02-2009, 04:50 PM   #6
big10ratrod77
Re: one bad squeek
i think i might try to get the rear u joint monday im a little tight on cash right now but i might have to replace a 3 by the way yall talk
