Eat My Rust
Vent window swings loosely, what broke?
My vent window used to be pretty weak, wouldnt stay open at 50+ mph like the passenger. Then a few weeks ago it went totally limp, it just pivots freely. I was wondering what holds it open? Is it a bolt or clam in the door, or the rubber seal that keeps it open?
Under Construction
Re: Vent window swings loosely, what broke?
there is a stud with a spring for tension on the bottom of the Vent Window. I will see if i have one to show you in my parts pile.... I borrowed a pic from the site, kind of dark but you can see the stud on the botton with the spring for tension, Yours could be really lose, or possibly broken.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 09-29-2009 at 02:49 PM. |
Eat My Rust
Can that spring be tightened?
Moderator
![]() Join Date: May 2007
Yes, you have to pull out your vent window to do this.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Is it possible to tighten that by just removing the door panel and reaching up there?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
Moderator
You can give it a try, but I'd think you would cut up your arms doing so. The window and regulator might also get in the way. I have the panels off of one of my trucks now, so I'll check it out tonight and see if it can be done.
Under Construction
possibly with a swivel and a long extension....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#8 | |
Under Construction
Rackman,,
buy a extendable magnetic tool...... ![]()
I own one....Ok, actually three or four of em....It was a "spur of the moment" deal...LOL
![]() Join Date: Jun 2007
There are locking tabs that fold over that nut. You would have to unbend them to tighten that nut. This will make a tight space seem even tighter, good luck.
#12 | |
Moderator
I just took an old beat up one apart for a learning session before I attempt a restore on a pair, only reason I remember
Eat My Rust
I'm skinny.. I think I can get up there. I need to pull my door panels off to silence some rattling linkage, this will add onto the todo list. Anyone have a close up pic so I know what I'm doing with out looking at it?
#16 |
Eat My Rust
Oh that really sucks.
#17 |
#18 |
Eat My Rust
I'll just have to attempt to pry it back or dremel it. I can reach up there, but that bolt is more protected than I thought.
#19 |
It should bend easy enough. They aren't that strong.
#20 |
Moderator
Be careful you dont break it when taking it off. A lot of times the nut is rusted on there, and PB Blaster is your friend.
How is the rubber? Now is the perfect time to pull them out and rebuild them completely.
#21 |
Eat My Rust
Don't have cash to put new rubber, but it needs it if I go threw a car wash. Which I don't, so, I don't need rubber.
#22 |
Don't forget to let us know how you made out.
#23 |
Eat My Rust
Haven't had time to mess with it. Getting a '75 Camaro retuned on it's new motor this week. Slowly getting it ready to whup another friend's '67 Mustang.. ha
