Under Construction
In-bed spare tire carriers
I have two inbed spare tire carriers. $30.00 each plus shipping. I will accept paypal plus 3%, or a USPS Money order.
charging the batteries in the camera currently, will post pictures later.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Re: In-bed spare tire carriers
Are they factory Blazer carriers? If so I would be interested
Under Construction
Jaros,
these were in trucks, I am not sure if blazers are the same or not. The black one has the button head bolts welded on the bottom.
So then the top would bolt to the bed side?
Under Construction
Yes sir, the top bolts to the lip of the bedside... I use to have a closeup of one installed, let me see if i can locate....
I borrowed a pic of chipflyers bed to show the mounting location: Yes, they were a factory option. P13 - SIDE MOUNTED SPARE. It shows the proper mounting location in the Assembly manual also. I also borrowed a pic of 673ontree pic that shows the spare mounted
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-02-2009 at 08:00 AM. |
![]() Join Date: Jan 2009
Do you have the hardware that attaches the tire to the mount?
Under Construction
Dasani, unfortunately i do not have the hardware, If you look at the thread below starting with Post 17 you will see details of the bolt that was on a NOS inbed tire carrier i have, but did not have the oversized washer and wingnut/nut . Alot of people are just using a carriage bolt with an oversized washer and nut to mount the spare... I have seen the bolt on ebay as a NOS item but i have never seen the complete hardware set...
http://67-72chevytrucks.com/vboard/s...d.php?t=348177
Unfortunately, it won't fit where I thought it would. 33" tire has to mount...Great price, but can't use it. Thanks for you're time
Thanks!
Under Construction
Bttt
Too Dumb To Know Better
I'll take one. shipping to 88005.
Thanks, Doug |
Under Construction
Doug, I will get a quote from USPS Monday. which one do you prefer, the red has no bolts, the black has the button head bolts welded on the bottom. Thanks!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-03-2009 at 10:17 PM. |
I'll take the red one.
PM me the details. Thanks |
CAN'T FIX NOTHIN
I used a camaro spare tire J-bolt and wing nut to mount my spare in the 67 picuted above , I have that same mount he has listed for sale , bolt's right up and work's great ,,,,,
any 70's GM car spare tire bolt and nut will work , easier to find than an original 67 to 72 truck factory bolt ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC Last edited by 19673ontree; 10-04-2009 at 08:23 AM. |
#15 | |
Under Construction
Thanks for the detailed info Sir!!!
#16 |
I will take the other one. Please PM payment info.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#17 |
Under Construction
I will get a quote Monday for you as well. Thanks Guys!!!!
#18 |
Under Construction
Shipping info sent via PM. Thanks Gentlemen!
