Old 10-05-2009, 05:11 PM   #1
gafiredog
spindles
does anybody know if any companies still make/sell lifted spindles for 73-87 c-10 2wheel dr. ? also same for 3/4 ton same years Thanks. art
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 10-05-2009, 05:23 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: spindles
there isn't, I think threes a way to use a 88-98 lift spindles with a ball joint change but most that lift 73 to 87 2wds use big block or 1 ton coils or if they can find lifting springs which is hard to come by and they did make lifting control arm but they caused a few problems, and there's also a body lift, I build a truck for a friend that had big block springs and 3" body lift and its a little higher than a stock 4wd
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
