10-04-2009, 01:27 PM | #1 |
Emergency Brake Rear Cables Too Short
After putting on my 6 inch lift, i noticed that my parking brake cables are way too short. what are my options to fix this. should i move the bracket and extend the front or intermediate cables?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
10-05-2009, 01:50 AM | #2 |
Re: Emergency Brake Rear Cables Too Short
This question has come up a couple of times or more over the years. I've never seen a conclusive answer. I think someone had said to use the long bed rears. I personally think just having a longer intermediary made would be easier.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
10-05-2009, 01:59 PM | #3 |
When I installed my 6" lift with 14 Bolt rear axle, I reused the parking brake cables that came on the 14 Bolt (connected to the backing plates), and relocated the cable stops that mount to the frame. I moved the cable stops back towards the axle such that they are now located near the front spring eye mounts for the rear leaf springs. I didn't have to change anything else, except for adjusting the stock parking brake shoe out (the semi-circular stamped steel bracket that the the two cables that come from the axle backing plates connect to). Works great.
10-05-2009, 09:48 PM | #4 | |
