10-07-2009, 05:47 PM | #5 |
Re: 9 Inch Rearend question
Most guys I know that have done this swap just set the pinion back to the stock setting for the 12-bolt. They put the pinion yoke @ plumb & measure the angle of the rear brackets on the 12-bolt rear. Cut the truck arm brackets off (or get new ones). Set the 9" housing w/the pinion yoke @ plumb & attach the brackets @ the same angle as they were on the 12-bolt. Tack them in place. Re-check the angles & if everything is good, weld them up.
