Old 09-29-2009, 10:37 PM   #1
imaguywithemail
imaguywithemail's Avatar
1970 c10 starting trouble!!!HELP!!!
So I'm almost done rebuilding my truck, was sticking the distributor yesterday and everything was going fine. Finally I got the distributor in what I'm almost positive is correct (had some trouble finding tdc, but i finally got it.). Then when i tried to start it it the starter was being really sluggish. So i figured 'the battery's probably just low.' so i hook it up to a battery charger, let it charge for awhile, then click it on to 50amp start and try to start it - and absolutely no change in starter speed. It got to the point where it wasn't doin anything just would give one click and that's it. Well I pulled the starter and battery and took them down to Kragen/O'Reilley's/Shucks/Checkers or whatever and tested them, they tested perfectly fine. So i stuck it back in today, and now it's turning over sluggishly again, but what I'm getting now is from the cable that runs from the battery to the starter, where it connects to the starter I'm getting sparks and smoke (tried it just now while it's darker out) and no starting. What I'm wondering, is any ideas you guys have on what's goin on. I'm supposed to be moving on Thursday and need this beast up and running. A little extra info: it is possible I have the wrong nut threaded on holding that thing on (right thread, wrong material maybe?) could that be causing all these problems? I've run through all my starting system wiring and everything looks fine. One more thing whenever the battery is hooked up my running lights are on constantly even though the light switch is off. Thanks for your guys help in advance!
imaguywithemail is offline   Reply With Quote
Old 09-29-2009, 11:41 PM   #2
2tons of fun
Re: 1970 c10 starting trouble!!!HELP!!!
you battery is probably wasted from the constant draw of the light, its a one wire fix, fix it.
2tons of fun is offline   Reply With Quote
Old 09-30-2009, 01:39 AM   #3
mclairmo
You are going to have to give us more info like battery age, how many volts it is reading now, how old is the starter, what type of starter. I would try another battery and see if that helps. If not, then I would test the starter myself with a known good battery and jumper cables.
mclairmo is offline   Reply With Quote
Old 09-30-2009, 03:20 AM   #4
imaguywithemail
I never have the battery hooked up unless I'm trying to get her to start and am working on her. I don't even go to the garage to get another tool without disconnecting it. and which wire would that be that i need to fix to stop that from happening, exactly.
Old 09-30-2009, 03:26 AM   #5
imaguywithemail
okay, so what I know about the starter: when I bought the truck when i was fifteen the starter was already at least 3 years old (it had sat for that long). That was five years ago. It did sit for one year when in a fit of insanity i sold the truck and bought it back a year later. When I was 18 i had the original 307ci engine replaced with a freshly rebuilt 350ci. I don't have a voltmeter to test the battery on me right now, i just ran down to Kragen/O'Reilley's and used their tester, and told me the battery health was still good, it's charge was a little low. I also took the starter out and down to Kragen's and hooked it up to the tester that they have. It tested good and the numbers it tested at were like smack dab in the middle between the low fail and high fail numbers. I did also have my girlfriend's '64 1/2 mustang hooked up with jumper cables, however it does have a 200ci engine and i have NO idea how old the alternator and battery are or what they are putting out.
Old 09-30-2009, 07:27 AM   #6
cdowns
cdowns's Avatar
i'd make sure you have clean bright metal connections for your ground wire and battery cable
Old 09-30-2009, 08:27 AM   #7
rwolf9653
more ideas than money
rwolf9653's Avatar
My jeep does this and it is a pain in the ass. If my battery is not at FULL charge, there is not enough power to turn over the starter, but it will click the solenoid. I figure that it is the starter drawing too many amps, in other words a bad starter that still works. You said that the battery tested low, so put a good charge on it and it should fire right up. My jeep has been like this for about 4 years, but it is off road only so I dont worry about it. Yours sounds like the same thing.
As for the parking lights there are several post on here that have the wiring diagrams laid out.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-30-2009, 12:35 PM   #8
hayhauler71
hayhauler71's Avatar
I would like to see a clamp on amp meter on the positive cable to find out how many amps this starter draws under load. Also check the resistance of your battery cables and always check to make sure cables are spot free clean and tight.
hayhauler71 is offline   Reply With Quote
Old 09-30-2009, 12:59 PM   #9
mclairmo
With an old starter, battery needs to be reading 12.6 volts or more. Also, batteries don't last much past 6 years and quick charging them can easily kill them. They really should be charged slowly with a trickle charger like the Battery Tender or similar. Also, make sure all your grounds are hooked up, body to frame, body to engine, engine to frame, etc. I have seen a lack of grounds prevent an engine from starting.
Old 09-30-2009, 01:21 PM   #10
El_Crnicero
El_Crnicero's Avatar
Did you do any work to the heads? If you adjusted your valve lash too tight, and this is your first time starting it would be very hard to start.
Good luck,
El_Crnicero is offline   Reply With Quote
Old 09-30-2009, 01:35 PM   #11
CMR
Hello, did you set the timing when you put the distributor in? It may be too high.
CMR is offline   Reply With Quote
Old 09-30-2009, 01:45 PM   #12
americanmusc1e
americanmusc1e's Avatar
I gotta agree, conections on the battery, on the battery clamp to cable, and on the starter and ground. you've got a bad connection somewhere, probably on the starter.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 09-30-2009, 02:28 PM   #13
mr48chev
mr48chev's Avatar
I agree with the guys who say you most likely have a bad connection or possibly a cable that is bad. Make sure that the spot on the engine where you have the ground cable is scraped bare so that the cable end has good contact with the block/head or ? All that nice paint will keep things from making good connections.
Make sure that the cable ends are tight on the cable especially if they are replacement ends and that there is no corrosion between the end and the wire if the cable.
Also as someone said, the timing could be a bit .
On the lights it may be a bad switch, pull the fuse and see if they go out.
Marked tail,stop,park,dome
If the lights go out you probably have a switch problem if they don't start checking for a hot wire making contact with the park/tail light circuit somewhere and I would start at the back bumper and see if there is some sort of mickey mouse tail light wiring hookup. All too often on these trucks someone has attempted to hook up trailer wiring and gets wires crossed.
If not that, look for extra switches or twisted together wires under the dash. The p/o may have done some "get by" wiring to get the lights to work and didn't turn off the switch or disconnect the wires.
Old 09-30-2009, 02:45 PM   #14
PowerPro
Sounds like a classic case of old battery cables. Cheapest easiest way to fix this problem is to replace both the positive and negative cables. When you reconnect the negative to the block, make sure you clean the connection to the block really well and get rid of ALL RUST.
I'm a generator mechanic and we get this issue all the time with generators that sit out in the weather all day everyday. Water seeps into the cables and corrodes them away. On the outside, they look great, but if you strip them back, they're destroyed with corrosion.
PowerPro is offline   Reply With Quote
Old 09-30-2009, 04:31 PM   #15
imaguywithemail
Thanks for all the good posts, I've got some things to do today now. As for the wiring for the running lights, I've got a pretty good idea where that problem's coming from (the taillight wiring that was near where the bed caught fire previously) so i'll check around there to make sure the wires aren't brittle and cracked. Also good idea on the grounds, I'm pretty sure now that I think about it that I might be missing one or two. thanks again,ad if anyone get's any other ideas let me know.
Old 10-02-2009, 12:32 AM   #16
2tons of fun
obvioulsy a hot feed wire.
Old 10-02-2009, 03:11 AM   #17
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Your truck is telling you where the problem is! It's impossible to have sparks and smoke at the connection and have a good connection. You probably have a bad crimp at the starter end of the cable. Buy a new positive cable!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-07-2009, 08:04 PM   #18
imaguywithemail
I got her goin! It looked like some battery acid had gotten onto the positive terminal of the battery or something. The terminal was darker colored than the negative, so I went and bought a terminal cleaner (didn't know where mine was) cleaned it and she began starting right again, no sparks, no smoke. Thanks for all the help.
