4/6 drop 20" wheels tire size and actual size
I am really wondering what is the actual brand, size and actual overall height of each of the tires front and back with those running a 4/6 drop.
I am going to do a 4/6 drop with 20" wheels and a 255 front and 285 rear. Going to try for a 45 series tire but it may be to tall. This way actual tire size and actual tire height might help make my decision between brands and actual size. Of course a pic is cool if you want too. |
Re: 4/6 drop 20" wheels tire size and actual size
you are still going to have in consistancies in the exact size. with the size say online they measure the tires mounted on a wheel. i can put my 255/35/20 on any wheel 8.5 to 10" wide not saying that i would but you can. and that will give you differences in height and width. different brands will give different sizes, some are casing size diff. and some are measured on diff width wheels. you can do the math and find out what tire size measures what and get an idea. hope this some what helps.
#3 | |
I want to run a good size tire on the rear and not rub in the front. I think in the rear you will be able to run a 30" tall tire no problem with a 6" drop. On the front i think youll need to stay closer to 29.5 with optimum rim spacing. |
ok i have 3" drop control arms 2" drop coils and s.u.a in the rear. i have toyo T1R 255/35/20 tires that measure mounted on a 9.5 wheel that i have is 27.02 tall by 10.03 wide and that is all around. I had 3" drop coils and the same size tire and they rubbed everywhere
#5 | |
i can find this tire in a 245/40-20 for the front
Falken Azenis ST-115 ![]() For the rear it is a 295/40-20 Falken Ziex S/TZ01 ![]() THis front tire measures 27.7" tall and is 9.6" wide on a 8.5" rim The rear tire is 29.3" tall and is 11.9" wide on a 10.5" rim What do you think? It is not easy to find tires in these sizes. I would want to run the largest possible tire from and rear while keeping overall circumference close to each other. maybe a little larger on the rear Last edited by vegaschevy; 08-14-2009 at 01:28 AM. |
4.5/6 drop on 245/35/20 front and rear
67-72 parts collector,…
![]() Join Date: Nov 2002
My 245/40-20's measure 27" tall. I think a 28.5" tire would be too tall.
The key will be using a wheel with the correct backspacing to "tuck" the rim.
Tirerack.com has a sale on 295/40's and 245/40's right now. They are BFG's KDW tires.
4/7 drop with 20x8 Eagle Alloys and 275/45 Falken STZ04's all around w/ zero rubbing. Hopefully going to 295's rear soon and baggin it.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom Last edited by smoked68; 08-15-2009 at 05:16 PM. |
Junior Member
anyone else?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
255-50-18 up front 295-40-20 in the rear continentals.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#13 | |
Happy to be here
![]() Join Date: Mar 2000
![]() ![]() ![]() ![]() 245/40/20 front and 295/40/20 rear took those wheels and tires and put them on the truck before I sold it. That was about a 4/6 drop. Last edited by jkade; 10-09-2009 at 09:45 PM. |
#15 |
I like the 18/20 setup and I like your wheels what kind are they
