how much drop ?
Just wondering how mush of a drop just front air bags will give with stock spindles on a 1970 1/2 ton with a 79 front end assembly . thanks
72 chevy former 1ton converted to 1/2 ton roller 350 engine , turbo 350 and a 12 bolt on leafsprings with a flip and drop springs ![]() |
Re: how much drop ?
At recommended ride height (ride height psi), bags typically yield about 2" of drop vs. stock coils. Calculating 'typical' front bag height @ 7" @ ride height & 'typical' minimum bag heights of 3", you can get about 6" of total drop when air'd out.
Redefining LowBudget
Re: how much drop ?
not sure this helps but heres mine with cupped LCA's on the stock spindle X memeber is about 1.5" off the ground sory the second one is a little fuzzy also keep in mind that my truck has a little air dam on the front to make it look lower
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Re: how much drop ?
thank alot guy for the info. Ive currently have 3 inch drop springs and with 28 inch tal tires the fender lip is 30 inches off the ground kinda high for my taste
Happy to be here
![]() Join Date: Mar 2000
Re: how much drop ?
If it were me, I would buy spindles before bags.
