Old 10-12-2009, 01:32 PM   #1
scotts1970
scotts1970's Avatar
Heater/AC question.
I have used this website many times in the past few years to help me figure out various problems and always appreciate yall's help. So today I have another I need help with.
1990 chevrolet 1/2 ton 5.7 automatic
Heater nor defroster would'nt get warm. Was on high and the highest temperature setting. Air was cool/lukewarm. Heard the ac compressor clutch cycling.
Checked under the hood and both heater hoses were hot. Engine was at operating temperature. AC lines were very cold and the compressor was cycling on and off.
I unplugged the clutch cycling switch and the engine cab air turned to very warm like it was supposed to.
Question: What would make the AC run at the same time as the heater? Could it be a defective control assembly? Hope not.
Thanks for the help in advance.
scotts1970 is offline   Reply With Quote
Old 10-12-2009, 01:37 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Heater/AC question.
When you select Defrost, as I am sure you already know, the A/C compressor will cycle on and off to provide what the MFR calls "CFC Linked Defrosting".
Now, as to why you have the problem you have....I'm at a loss.
Member Nr. 2770
Old 10-12-2009, 01:52 PM   #3
scotts1970
scotts1970's Avatar
Actually I didn't know that so I am glad you told me. Learn something new everyday.
Old 10-12-2009, 07:36 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Oh yeah, and if the temp control is set to the coldest setting, then the air that comes out of the vents will be at its coldest. Using the temp control will show you that it is probably working okay. If it is set so that the windshield fogs up on the outside, then it is probably too cold/too humid.
Member Nr. 2770
