overdrive transmissions in 4x4 c20
whats the best option. im wanting the gas milage but would need something to hold up to a built 350 and heavy hauling occasionally. i would also like to keep my np 203 transfer case just to save money but wouldnt be opposed to an upgrade on it either.
Re: overdrive transmissions in 4x4 c20
a 4l60 and a 208 for a th350 mate together seemlessly and the 4l60 will take a built 350
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
You can use any of them.Just build the trans for the motor.
got the same questions
also is there anyway to run the 4l60 without a computer
208 is passanger side drop out of the 80's body trucks, the shifter is on the floor. If you use this make sure you get one from a th350 or 700r4 and get the adapter also. The 4l60 will not shift without a computer but the conversion computers are rather cheep these days. The case from a 88-91 full size blazer(241 iirc) will also work, but it has an electronic speedo . so it is a perfect choice for someone who is going to straight axle a truck from 88-curent that has a 4l60.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 10-14-2009 at 03:39 PM. |
