Old 10-14-2009, 09:52 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Is the front door on a crew. and
Is the front door on a crew cab the same as reg cab. how much trouble is it to take a 4wd crew cab duelly to a 1/2 ton 4wd
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 10-14-2009, 10:04 PM   #2
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: Is the front door on a crew. and
Front doors are the same. some of the 3/4 four door the spring perches are the same as a 1 ton and would have to relocate them on the 1/2 ton rear.not sure on the front axle
powerdriver 1958 is offline   Reply With Quote
Old 10-15-2009, 05:36 AM   #3
ghettoluxury
ghettoluxury's Avatar
Why would you put 1/2 ton running gear under a truck like this? The axles you have can be converted single wheel if this is the issue.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
