Truck cab on a Suburban frame?
Thinking about buying a '77 suburban for parts...I'll have a lot left over when I'm done. Just theoretically speaking, could you take the body off of a suburban frame, and bolt on a truck cab without the bed? Would everything line up right?
I'm starting to think it would make a good flatbed...am I nuts? ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Truck cab on a Suburban frame?
the chassis on a burb is wider so it wont work.. trust me i bpouht a burb trailer hitch and it wouldnt work it was too wide
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Hmm...aren't the front clips basically the same as the ones for the trucks? I wonder if maybe the 'burb frame is wider at the back but not the front?
Hmmmmmmm.............. ![]() |
Not sure about a regular cab but a crew cab will
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
not mine but I built a shortbed crew for my cousin using the front of a burb frame everything to the second set of cab mounts lines up perfectly so doing this should work out fine
Sweet!
![]() ![]() Is the suburban wheelbase the same as a LWB truck? |
Still plays with trucks
That is really odd. My trailer hitch and rear bumper came off of an 86 Suburban and bolted right up to my 67 C-10 and are now on my 78 K20. Maybe they gave you the wrong year part?
![]() Join Date: Apr 2009
frames are the same width and a burb frame is same wheelase as a longbed. just need the rear cab mounts off the old pickup frame. fronts are same
1981 Chevy C30 440 Holmes 42K one owner miles |
Hmmm, so I guess now I'll have to find another parts truck to rebuild the parts suburban after I take a bunch of stuff of it?
![]() Maybe it's time to have the doctor adjust my meds.... |
Actually I believe the suburban wheelbase is slightly less than a longbed reg cab, by a couple of inches.
The info I found shows the sub to be 129.5" and I know the longbeds are 131.5".. Wouldn't make a lot of difference but the rear tires might be visibly more to the front of the wheelwell if a longbed was mounted on a sub frame. I believe the picture of the crewcab above may be on a reg cab lwb frame. Similar to Cousin Willard,, ![]() ![]()
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 10-16-2009 at 11:01 AM. |
you may be right. i found this on line
The fuel tank was moved to a spot outside the cab, on the right frame rail. C10/K10 pickups with an 8-ft. box had a 131-1/2-in. wheelbase, also used for many 1/2-ton chassis models and C30 models. C20/K20 trucks, except Suburbans, were on a 127-in. wheelbase.
#13 | |
I'll have to look at the buildsheet on my C30 and see how long it is... Definately not an issue though, I'm just trying to build an old junker with a custom flatbed. Good beds are about the only thing in short supply around here. ![]() Last edited by Number21; 10-15-2009 at 08:59 PM. |
Yesterday, 06:50 PM #12
truckfan Registered User Join Date: Apr 2009 Location: Lawrence KS Posts: 141 Re: Truck cab on a Suburban frame? -------------------------------------------------------------------------------- you may be right. i found this on line The fuel tank was moved to a spot outside the cab, on the right frame rail. C10/K10 pickups with an 8-ft. box had a 131-1/2-in. wheelbase, also used for many 1/2-ton chassis models and C30 models. C20/K20 trucks, except Suburbans, were on a 127-in. wheelbase. __________________ 1977 C-10 Bonanza 454. Tilt, Cruise, PW/PL A/C (all works)114K original one-owner (not me--I'm second) miles. Square body, 2 door regular cab long bed pickups had a 131.5" wb. Square body Suburbans had a 129.5" wb. Last edited by Dooley; 10-16-2009 at 11:56 AM. Reason: Others were editing their mistakes |
#15 | |
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#16 |
so did they list the suburban wheelbase in the glove box?
I picked up a used glove box liner that had a spid label that said 129.5 wheelbase...I assumed it was a long bed truck. What is the wheelbase of a crew cab long bed?
#17 |
Looong
![]() 164.5"
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 10-29-2009 at 06:46 PM. |
#18 |
holy schmolie.....
#19 |
http://chuckschevytruckpages.com/framespecs.html there you go chucks chevy pages has a listing of all the chevy truckframes used and there sizes and a ton of info on interchangeabillity
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
