06-10-2009, 03:33 PM | #1 |
Hood Hingle holes
Hey guys, I was trying to find the thread on drilling the holes in a 58-59 cab so I can put a 55 front clip on it.
Im looking for how (where) to drill the holes for the hood hinges on the cab. Thanks, Ben
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
06-10-2009, 05:14 PM | #2 |
Kid's Mechanic
Re: Hood Hingle holes
Any Ideas?
06-10-2009, 08:27 PM | #3 |
I used the same holes.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
06-11-2009, 08:27 AM | #4 |
I'm sorry guys... I must be mistaken.. I Thought I saw somewhere where the holes were different.
06-11-2009, 08:52 AM | #5 |
Well I found the thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=341064 Anyone know how to accomplish the holes for the hinges?
06-11-2009, 01:49 PM | #6 |
Hollister Road Co.
Take a straight edge and clamp it onto the firewall lip. Measure down from the under side of the straight edge 2 1/8" for the top hole and 5" for the bottom hole. The vertical line should be 9" from the hand brake/column support welded nut that is on the firewall. The old holes should be 2 3/8" down and 5 3/4" down and 9" from that welded nut.
06-11-2009, 02:14 PM | #7 |
ok... so for a recap... from what you said it sounds like both the new and the old holes are on the same vertical line 9" from the welded nut mentioned.
So if the existing ones are 2 3/8" & 5 3/4" down then all I should have to do is: drill a hole 1/4" above the existing top hole and drill a hole 3/4" above the existing bottom hole. Is that correct?
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! Last edited by bensimmons_05; 06-11-2009 at 02:15 PM. |
06-11-2009, 02:43 PM | #8 |
Hollister Road Co.
"from what you said it sounds like both the new and the old holes are on the same vertical line 9" from the welded nut mentioned. So if the existing ones are 2 3/8" & 5 3/4" down then all I should have to do is: drill a hole 1/4" above the existing top hole. drill a hole 3/4" above the existing bottom hole.
Is that correct? Yes |
06-11-2009, 02:45 PM | #9 |
That helps out a bunch
Thank you very much for that info Dave!!! From what I have seen you are a wealth of knowledge on this board
06-12-2009, 07:46 AM | #10 |
A320 Pilot/USAF Retired
I'm having the same issue with mine 'cause it's actuallly a 58 with the 57 clip. Let us know how it turns out!!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
06-12-2009, 10:51 AM | #11 |
On mine (before the tilt hood) I used the 55 57 hindges and used the factory holes. All I had to do was grind away the top corner so it would clear the lip that gose around the firewall. I'm not sure way you would have to drill any holes at all.
06-12-2009, 11:14 AM | #12 |
hmmmmmmmmmmmmmmmmmmm.... interesting. The plot thickens.
06-12-2009, 11:52 AM | #13 |
I also had to elongate the holes on the hindge to try and allow it it sit LOWER on the firewall, but the hood is still high in the rear.
I've asked Dennis57 to take measurements from his 57 since he has the front clip removed. Would like to get a definite answer too!
06-12-2009, 03:56 PM | #14 |
Hey guys. I measured the holes from the bottom of a straight edge that was laid across the top of the lip on the firewall and I got.
2 3/8 to the top hole and 5 3/16 to the bottom hole. Hope this helps. |
06-12-2009, 07:44 PM | #15 |
AWESOME, Thanks Dennis!!
06-12-2009, 07:54 PM | #16 |
Ben,
Can you post some pics similar to these from Dennis57, or post the measurements??
06-15-2009, 09:11 AM | #17 |
Yeah, I think I can handle that... it will be this afternoon though.
10-15-2009, 02:27 PM | #18 |
Ben,
Looks like you have your front clip removed now. Can you post the measurements from your cab using the method Dennis57 used? Thanks!!!
10-16-2009, 09:59 PM | #19 |
The holes on the 58 cab are
2 3/8" & 5 3/4" I have a 55 Cab I will check in the morning. I also have a picture i can post then too. Dennis it looks like your cab is a cross between a 55 and 58 from the info given.... you have a hybrid
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! Last edited by bensimmons_05; 10-16-2009 at 10:00 PM. |
10-17-2009, 08:59 PM | #20 |
Thanks Ben! I'm curious the see what the specs are on the 55!!
10-17-2009, 09:55 PM | #21 |
I had the same issue. All I did was make the holes bigger on the hinges and everything lines up perfect.
http://community.webshots.com/user/56myway |
10-18-2009, 02:21 PM | #22 |
Here is the picture for the 58 measurements (sorry for poor quality)
The measurements for the 55 were 2 1/4" for the top and 5 1/8" for the bottom (both measurements are only about 1/8" off in the same direction from the measurements listed by dwcsr) At least you can clearly see there is a difference between the two. The angle on the second picture makes it look like less than 5, but I assure you its just a little more that 5"
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! Last edited by bensimmons_05; 10-18-2009 at 02:23 PM. |
