angle strips
how have you guys replaced the angle strips in your bed mine seem to be rusted on are there rivits I already cut all the bolts that I could see and they still dont budge
Re: angle strips
They are spot welded on. The corners should go over the top of the old ones.At least I've seen some that do. I took mine off and my bedsides are warped some what. New ones do not attach to the bedsides.
http://rides.webshots.com/photo/1126...54302821swdZif Later, Ben Last edited by chevytrucknut61; 10-18-2009 at 11:02 PM. |
Re: angle strips
what did you use to remove them
Re: angle strips
I used a spotweld remover (a 3/8 drill bit) being carefull to only go thru the strip.
Re: angle strips
A spot weld cutter will avoid drilling through the bed side. After cleaning and prepping the bed side, I would spot weld the new edge angles back in place.
