fuel sending unit removal
Need some guidence on getting the sending unit out, I played with it a bit but almost bent part of it, any tips or tricks will be appreciated, thank you
406 Powered
Re: fuel sending unit removal
Very easy. First remove your seat,next unplug the wire for the sending unit.
Next there is a lock ring you can use a screw driver on that holds the sending unit in. Lay the head of the flat head on the ring and tap it counter clock wise picking the screwdriver up and going to a differnt spot until the ring just pops out. Now just lift up on your sending unit and manuever it out of the tank. hope this helped......................
70 GMC 68 c10 2002 silverado 72 4x4 |
its all about the +6 inches
a brass drift is the prefered tool over a screwdriver. Less damage to the locking tabs and less sparks.
70 Chevrolet=Obsession
LHM is right unless you relish taking a trip to the moon via the Chevron Supreme rocket!
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
I dun gradjiated collij!!!
Probably want to have the cap off as well, pressure and a gaping hole dont mix...
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
