10-17-2009, 12:45 PM | #1 |
mustang II front suspensions.....
so i know a few guys are running the fatman kits and really like them. just curious what other people are running and how they like theirs.
10-17-2009, 03:12 PM | #2 |
Re: mustang II front suspensions.....
What advantage does a MII bring to our trucks?
10-17-2009, 04:12 PM | #3 |
alot of gus one here run a "dropmember" which is like what your talking about. They are made by a boardmember/vendor on this site. The name is porterbuilt streetrods. There is tons of info about the product, just do a search for dropmember.
10-17-2009, 10:08 PM | #4 |
what advantages does it not bring?
10-18-2009, 01:16 AM | #5 |
10-18-2009, 09:32 AM | #6 | |
Plus there is the fact that the MII suspension was designed for a small car with a 4cylinder engine and more than 1000lbs less total weight.
Personally, I have never been a fan of that front suspension set-up under any kind of big car either. By the time you "up-grade" everything, the cost has gotten a litte crazy too. The money would be much better spent on the stock suspension.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-18-2009, 11:08 AM | #7 |
All good points, i was just wondering mostly on the rack side of it. seems like you eliminate alot of linkage when using rack and pinion. I guess that is why porterbuilt is so successful with his kit. keeps all the truck stuff and gets rid of all the linkage.
10-18-2009, 11:26 AM | #8 |
Exactly.
10-20-2009, 06:40 AM | #9 |
If you don't care about handling or a smooth ride on rough roads then get one.I would keep what you got get better a arms.Flaming river has a rack and pinion kit for the 73-87 trucks you might be able to make it work with yours.Or i think porterbuilt c4 member you can use coilovers on.
