10-19-2009, 11:13 PM | #1 |
Pat
Deluxe Side Markers
I aftermarket deluxe side markers, not sure the brand
The stainless strim fell off so i super glued, silicone, and epoxied them, no luck. First i think it was the heat and now that winters coming i think its the cold. Any ideas? Thanks Pat |
10-20-2009, 12:06 AM | #2 |
its all about the +6 inches
Re: Deluxe Side Markers
typical repro marker lamp. I don't know that anyone has found a real solution.
10-20-2009, 12:11 AM | #3 | ||
'69 Chevy SWB
http://67-72chevytrucks.com/vboard/s...d.php?t=363822
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
10-20-2009, 12:44 AM | #4 |
I don't know that it is a solution, but it does tuck it in to where it won't get smacked or bumped.
Plus it just looks bad ass! |
10-20-2009, 01:14 AM | #5 |
From what I have read it is better to just redo some original ones. Are the sets from 1970's vans the same? There should be lots of those in the boneyards.
"You can take the man out of PA, but you can't take PA out of the man" |
10-20-2009, 05:44 AM | #6 |
The vans are the same.
I use 3M trim adhesive and have had good luck with it holding the stainless onto the lense. It is a bit messy to use but it works. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-20-2009, 01:28 PM | #7 |
Could be mold release that is still on the lenses when they were made, just not cleaned enough or properly ??
Clean well and use proper adhesive like the 3M mentioned above....yea it's messy but works well. Dave
Dave & Marilyn in Rio Rancho NM....1967 Chevrolet C-10 long step side.....250 3 spd. ..... 1968 Chevrolet C-10 long step side.....325 hp 350 4spd.....3" Exhaust....etc. 1965 Chevrolet Suburban K-10....292 4spd....cam....etc. Bow Tie Baby |
10-20-2009, 03:44 PM | #8 |
Firefighter
I know that tucking them in wouldn't help, my buddy put some on his truck outside last winter, did not even move the truck came out the next morning and all of the trim had fell off...... Cheap repro crap!!! He used some windshield urethane to glue them back on and so far they have stayed!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
10-20-2009, 07:08 PM | #9 |
Cool Truck
I have a set off an old van or something and my trim has fallen off of two. I just superglued it and it has held.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
10-20-2009, 07:16 PM | #10 |
the ones I had on my truck which are brand new one of them the has the trim cpoming off of it...no big deal as I will glue it back on if I ever put them back on as I went with van side markers and I like them a hell of alot better....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-20-2009, 07:25 PM | #11 |
Cool Truck
I always thought those van markers look nice, but the deluxe is much better imo
10-20-2009, 09:04 PM | #12 |
Gorilla glue will hold them on also.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
10-20-2009, 09:59 PM | #13 |
What years of van side markers work ??
10-20-2009, 10:18 PM | #14 |
diggertodd
Yup, funny story, just finished my truck 2 years ago in the dead of winter (about 15 degrees) It was a sunny but cold day.
I told my friends at the local breakfast cafe I would bring the truck up to show it off... so there are 5 friend standing in the lot when I pulled up. Got out, shut the door, and 7 of the 8 little trim rings on the side marker popped off all at once and hit the ground, EVERYBODY was about on the ground laughing. Took them all off (the one last trim ring) sanded off the glue and polished the plastic and left them off.... Last edited by diggertodd; 10-20-2009 at 10:19 PM. |
10-20-2009, 10:49 PM | #15 |
van markers from 70 or so, when they went to the big vans, and then up till 90 or so when they finally retired the old van dura and went to the savana.
The early years had the same as our truck's base model lenses, the mid 70's to mid 80's had the delux ones that ours had (the ones this thread is actually about) then the smooth ones as seen on big al's truck as seen above finished out that van body style. The last ones put out 2 to 3 times the light over the early or mid year style. Last edited by Longhorn Man; 10-21-2009 at 04:08 PM. |
10-21-2009, 01:53 PM | #16 | |
Would the housing from the van work or be needed, or just use the old metal ones from the trucks?? Dave
10-21-2009, 02:03 PM | #17 |
PROJECT 7DEUCE
I actually used model glue when mine fell off and they have been on there ever since..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-21-2009, 04:09 PM | #18 | |
We are talking about the plastic side maeker lights that mount to the fender with 2 screws per lens. |
10-21-2009, 04:18 PM | #19 |
mini truck racer
I got the clear 2 part epoxy from Lowe's . I think Elmers or Loc-tite . Clean it up mix it and clamp or tape it . Lots of uses for it . It is thick and goooy like honey or syrup .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
10-21-2009, 06:55 PM | #20 | |
Sorry for the confusion, and THANKS for the info. Dave
10-21-2009, 09:06 PM | #21 |
Pat
Ya i think ill try the epoxy again, maybe clean it better.
Thanks for the replies Pat |
