Old 10-22-2009, 02:15 PM   #1
Ackattack
Ackattack's Avatar
Torque specs
So installed my new spindles last night and for the life of me I could not find the torque specs for the lower ball joint or the brake rotor spindle.
It's kinda wierd cause the book I was looking at had the upper ball joint nut torque spec....you'd think the lower ball joint nut spec would be right there....nope.
BTW: 72 1/2 ton front suspension specs.
Ackattack is offline   Reply With Quote
Old 10-22-2009, 02:23 PM   #2
steelhorse
steelhorse's Avatar
Re: Torque specs
German torque-goodundtight
steelhorse is offline   Reply With Quote
Old 10-22-2009, 04:10 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Torque specs
These are the ones I saved from someone when I was looking.
C10 , C20/30
Upper ball joint 70 / 120
Lower ball joint 120 / 215
Tie rod ball joint nut 30 / 50
Tie rod clamp 132 in# / 132 in#
Idler arm mounting bolts 30 / 30
Idler arm to relay rod 60 / 60
Pitman Arm 60 / 60
Pitman arm to selector shaft 125 / 125
All values are in foot pounds unless noted.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
