Old 10-17-2009, 10:52 PM   #1
KrazyRay
KrazyRay's Avatar
72 Chevy Pickup Bed Trailer
A couple months ago, a board member asked if anyone had made a trailer out of the back half of a truck. I have made a few of them. Here's one I did this weekend.
I pulled the cab off and removed the brake and fuel lines. Then I cut off the rivets holding the front cab mounts and exhaust hanger.
I cut the frame just in front of the cab mounts and measured 36 1/2 inches from the frame cut to the relief cuts to fold the frame together. Also, I cut small angles at the front to give me an inch or so to weld the frame rails together.
Next, I took the angle grinder to joint prep for the welds.
It may not be as pretty, but I prefer lap welds over butt welds where the frame folds. To make the laps, I grab a ford tool and beat one part of the lap down and the other part up. I weld the frame fronts together and the 5000lb. A-frame coupler fits the angle almost perfect. I will get pics as soon as the site will allow.
KrazyRay is offline   Reply With Quote
Old 10-18-2009, 03:00 AM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: 72 Chevy Pickup Bed Trailer
Subscribed!
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 10-18-2009, 10:43 AM   #3
kevmic28
kevmic28's Avatar
You can use photobucket to host pics and just post the image script to show the pics on here.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 10-20-2009, 06:19 PM   #4
KrazyRay
KrazyRay's Avatar
pics
Old 10-20-2009, 06:24 PM   #5
KrazyRay
KrazyRay's Avatar
more pics
Old 10-20-2009, 06:40 PM   #6
KrazyRay
KrazyRay's Avatar
The next thing I will do is install a safety chain, pick up a flat 4 trailer connector, or if you want the backup lights to work than it will take at least a 5 pin (I usually step up to a more common 7 pole) Next, I will pressure wash the trailer and possibly use a flapper disc on the frame. I paint the frame with rustoleum black and the bed with rustoleum white. It takes about 1/4 gallon with 25% acetone as a thinning agent to do a trailer.
Here's some pics of a trailer I did with hydraulics and one that I used a caddy el dorado axle to lower down by about 5 inches.
Old 10-20-2009, 07:58 PM   #7
Rob H.
Rob H.'s Avatar
I still say you Caliornia guys are too spoiled,lol cutting up trucks like that for trailers, sure wish I had that cab!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 10-20-2009, 11:11 PM   #8
KrazyRay
KrazyRay's Avatar
I have 9 of these cabs...wish I could figure out how to get them to the rust belt!
Old 10-20-2009, 11:15 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Come on down and pick one up!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 10-21-2009, 02:21 AM   #10
sleepertruck72
sleepertruck72's Avatar
Krazy Ray,
I like the hydraulic dump bed, what is needed for this conversion ? Battery, hydraulic ram,hoses, I am tired of dump runs where I have to actually work ! Does the tailgate bottom out when tilted or is it removed ?
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 10-21-2009, 08:23 AM   #11
KrazyRay
KrazyRay's Avatar
sleepertruck72, The hydraulic dump was pretty simple. On the pass side, I mounted a battery box on the outside of the frame rail. I used a 7 pole trailer wire connector to allow for trickle charging the battery while driving. On the driver side, I mounted the pump assembly (12 volt pump motor, hyd. res. all one unit) to the outside of the frame. I made a few notch cuts on the bed cross ribs and attached the scissor ram. What made it easy was the complete hydraulic setup came off an old caltrans truck.
Old 10-21-2009, 10:26 AM   #12
Rob H.
Rob H.'s Avatar
Only 2 things keeping me from coming to get one, time and money, seems that's the major hold up on most of my projects. The two also never coenside, always one without the other! Maybe someday, sure would like to get out that way again, it's been 24 years since the last time.
Rob
48 Willys CJ2A
Old 10-21-2009, 10:52 AM   #13
tim21391
tim21391's Avatar
i would of loved to have that white bed
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 10-21-2009, 11:43 AM   #14
rambler
MOVE OVER
rambler's Avatar
nice job! it sucks that that bed is nicer shape then mine! I saw one the other day loaded with wood, looked in like new shape, pulled by a old beater car...
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 10-22-2009, 12:06 AM   #15
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Truck killers!!!!!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-22-2009, 12:50 AM   #16
KrazyRay
KrazyRay's Avatar
Originally Posted by unclewatts View Post
Truck killers!!!!!
A guy I used to buy longbed beds from said that the only thing a longbed truck is good for is parts for the short beds. That being said, I'm putting together a 72 k20 super cheyenne longbed.
Wait until you see the next truck I've killed....It will be posted in the square body section in a few days.
Old 10-22-2009, 05:14 PM   #17
unclewatts
unclewatts's Avatar
Actually I'm just kidding. The truth is that the more trucks that you make into trailers, the more rare and valuable mine becomes!
Old 10-22-2009, 07:19 PM   #18
72 cheyenne pdx
72 cheyenne pdx's Avatar
That's what I keep saying about long beds. Keep shortening them to short bed, and someday I may have the only longbed in existence......
72 cheyenne pdx is offline   Reply With Quote
