Old 10-21-2009, 01:07 PM   #1
ClifBlazer
ClifBlazer's Avatar
72 jimmy to 67 chevy blazer
well I am going to get started parts are coming in started to take apart 67 lets see if I can load pic?
ClifBlazer is offline   Reply With Quote
Old 10-21-2009, 01:20 PM   #2
ClifBlazer
ClifBlazer's Avatar
Re: 72 jimmy to 67 chevy blazer
got bed off by my self a challang to say the least
Old 10-21-2009, 01:50 PM   #3
ClifBlazer
ClifBlazer's Avatar
heres the plain take 67 truck and remove body clean up frame change brakes and drive train put jimmy tube on after body work here pic. of jimmy its in a barn with suff stacked all around it.well I quess not won't load?
Old 10-21-2009, 07:52 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you putting a Jimmy tub on a 2wd shortbed frame?
I assume you know the wheelbase is different?
Keith
Convert to disc brakes.
Old 10-22-2009, 02:48 AM   #5
ClifBlazer
ClifBlazer's Avatar
11'' shorter in between cab and wheel well not shore where to cut out figered I'd find out when tube and frame meet do you think this bed is any good to any one?
Old 10-22-2009, 04:26 AM   #6
OARNGESI
OARNGESI's Avatar
looking forward to seeing this you should be able to sell the bed try puting it up on craigslist
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-23-2009, 04:00 AM   #7
ClifBlazer
ClifBlazer's Avatar
lolife have you done this frame cut or have you seen a thread that shows it think I down loaded jimmy pic.
Old 10-23-2009, 04:23 AM   #8
ClifBlazer
ClifBlazer's Avatar
more pic. of jimmy have to reduce them to fit
Old 10-23-2009, 06:06 AM   #9
lolife99
lolife99's Avatar
No, I haven't seen this done. All the body mounts will have to be moved on the new frame.
I think it would be easier to add 2wd front suspenion to the original blazer frame.
Many people have done this "conversion".
Keith
Old 10-23-2009, 03:40 PM   #10
ClifBlazer
ClifBlazer's Avatar
I haven't found a frame that some one doesn't want as much as a truck for
Old 10-24-2009, 04:53 AM   #11
ClifBlazer
ClifBlazer's Avatar
any body seen a p/s pump like this?
Old 10-24-2009, 06:10 PM   #12
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Good grief, how many mirrors did that blazer have?
low'n slow is offline   Reply With Quote
Old 10-24-2009, 09:07 PM   #13
Rokcrln
Rokcrln's Avatar
I agree!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-25-2009, 03:33 AM   #14
ClifBlazer
ClifBlazer's Avatar
SO WHAT DO YOU THINK Ive had this 72 blazer 4wd one owner truck thats tub is les than all there, no rocker box d/p side ,floor pans = to most I see ,supports half there so tube is ruff .jimmy I have has better tube this is the one I would put on 2wd swb frame so my thought I would have one of each 4x4 low2wd now you all got me thinkin DO I CUT THIS FRAME OR DO I MAKE A 4X4 OR DO I GO LOW WITH 4X4 FRAME than ether sell xstra parts or keep in tell i find chepper frame that i make some thing out of
Old 10-25-2009, 05:49 AM   #15
ClifBlazer
ClifBlazer's Avatar
And
Old 10-25-2009, 09:27 AM   #16
lolife99
lolife99's Avatar
Don't cut the short wheelbase frame.
Find another 4x4 blazer frame to convert.
I wish I had something to trade for your stepside.
I have complete disc brake front crossmembers if you need one for your conversion.
Also trailing arms and crossmembers.
Do yourself a favor,... and find another blazer frame.
Keith
Old 10-25-2009, 08:15 PM   #17
ClifBlazer
ClifBlazer's Avatar
Thanks for input lolife you have good point swb frame is much better THan cutting down a lwb Besides the cab isnt so bad but the roof and drip rail are going to need work po did floors but didn't do kicks with the floors WHY do they do what they do? Your there and not do all thats needed done
Old 10-26-2009, 01:45 AM   #18
ClifBlazer
ClifBlazer's Avatar
floors buy the p/o
Old 11-05-2009, 07:28 PM   #19
ClifBlazer
ClifBlazer's Avatar
not going to cut swb frame may destroy 4x4 and make it a coil over frame. if I cant find one thats more in line to use ( broken axal bad t case or just a good deal) watchin C L
Old 11-05-2009, 11:40 PM   #20
OARNGESI
OARNGESI's Avatar
HERES A THREAD I FOUND ON ADDING TRAILING ARMS TO A 4WD BLAZER FRAME YOU MAY BE INTERESTED http://67-72chevytrucks.com/vboard/s...d.php?t=218156 I GOT A 70 BLAZER IM DOING LIKE THIS
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 11-06-2009, 03:18 AM   #21
ClifBlazer
ClifBlazer's Avatar
thanks I think I got a frame Oboy
Old 11-13-2009, 08:01 PM   #22
ClifBlazer
ClifBlazer's Avatar
Im going to get the frame from teeitup tommrow 72 jimmy 4x4 so know cutting swb truck [dont worry I have planes for it ]pics will come with frame
Old 03-12-2010, 02:23 AM   #23
ClifBlazer
ClifBlazer's Avatar
well parts shopers build for blazer is on hold so short bed has been getting some atinchin
Old 03-12-2010, 02:25 AM   #24
ClifBlazer
ClifBlazer's Avatar
found rust in coul lets start cuting it out
Old 03-12-2010, 04:17 AM   #25
ClifBlazer
ClifBlazer's Avatar
and windshild frame
