Old 10-09-2009, 09:27 AM   #26
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Help Me Identify This Part
if you have the complete factory linkage, i would stay with it. Just weld the groove up, and your in business.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-09-2009, 09:38 AM   #27
67cheby
67cheby
67cheby's Avatar
hey Mike Nevil at Springdale AR 1 800 825 2777 i am sure he would have one
67cheby is offline   Reply With Quote
Old 10-09-2009, 10:16 AM   #28
72CST4x4
It's only a minor addiction
72CST4x4's Avatar
I use 3/8" x 2 1/4" shoulder bolts to replace the worn pins. Just cut the end of the shoulder bolt off, grind a taper on the end to match the factory one, knock out the original pin and weld the new one in place. Looks just like new!
72 Blazer CST 4x4
72 Suburban K-10
72 B.B. 402 C-10
70 K-10 4 spd
1970 GMC 2500 with 24K actual miles
Current project- 69 GMC swb
72CST4x4 is offline   Reply With Quote
Old 10-25-2009, 09:18 PM   #29
ChadGiles70
Can you use a 2wd linkage setup on a 4wd vehicle. I'm guessing I have a 2wd setup for my 4wd blazer but the rod seems to be to short. Does any one have pictures of it installed?
ChadGiles70 is offline   Reply With Quote
