01-08-2009, 10:18 AM | #1 |
Cruise Control Intermitent Wipers(Factory)Tilt
I have a tilt column that I am planning to put into my 85.
The truck has no cruise and no intermitent wipers. The tilt column has the cruise and delayed wiper signal lever. But no interval wiper module. Does anyone have a photo of the wiper module inplace on the column? Does anyone have some underhood photos of a factory cruise set up? If you have parts availible see the WTB section. Thanks!
My Truck's not leaking its marking its territory! |
01-11-2009, 12:17 AM | #2 |
Happy to be here
Re: Cruise Control Intermitent Wipers(Factory)Tilt
Anyone?
01-11-2009, 12:46 PM | #3 |
Thanks for the bump.
01-11-2009, 10:10 PM | #4 |
I would also like to see this set up. If anyone could help please.
10-22-2009, 05:22 PM | #5 |
back from the dead.......
CHEVY ONLY |
10-22-2009, 09:30 PM | #6 |
not whats wanted but thought i'd share anyways... i happened to score an intermitent wiper switch for the dash today at pick n pull. there was a cherry 85 stepper w/ what looked to be 117k miles. was a clunker turn in. very sad day seeing all those trucks with pink painted on the engines and parts RIPPED off. even seen a 454 in a 90's burb with 60k painted pink and a 99 ls5.3 in an ecsb truck. unbelievable.... anyways back on topic!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
10-23-2009, 07:32 AM | #7 | |
I also have cruise, which I installed from a service kit, but it's on a V6. Let me know if you'd like some pictures (I don't have any underhood shots handy). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-23-2009, 10:16 AM | #8 | ||
the P.O. had swapped in a newer tilt column with wipers and cruise on the turn stalk....so now I'm going to convert to use it Quote:
I would like to see the cruise set-up if you don't mind snapping some pics
CHEVY ONLY |
10-26-2009, 07:49 AM | #9 |
Ok - here's some cruise pics (disregard the dirty engine compartment, please).
As I mentioned, I added cruise to my truck as a service kit. It came with that vaccum diaphram, the mounting bracket, the fittings (on the throttle lever) and the necessary linkages. (It also came with the cruise stalk and necessary modules, switches and wiring). Hope that helps, let me know if you have any followup questions. K
