Just a car guy
rams horn manifolds
will rams horn style manifolds clear the frame and crossmember on a 69 truck?
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
Re: rams horn manifolds
Back in 69 the GM engineers seemed to think so.
#3 | |
The Older Generation
I have a '69 down to the bare frame with the motor in it but it is a big block so I don't think pictures of it would help you. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-23-2009 at 12:45 PM. |
Under Construction
I agree with Leon... If you have the correct ones they will clear. with my experience, you will need the ones that angle towards the back instead of dumping straight down The straight dumps will interfere with the starter unless you go with a mini..... ...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Here are my two cents worth, I am building a 67 short bed using a 72 frame, the 67 has a home grown 327 with the rams horn manifolds, I media blasted them and painted them VHT ceramic coating (came out extremely nice) my ultimate plan are a very good set of shorty block hugger headers, but that is when I replace the 327 with a nicely built 350.
I have a 72 with 350 and my ram horn manifolds dump out the center ,,which would put the header pipe straight into the crossmember. Ya need ones that dump out the rear ,as previously stated.-KB
I believe 2 WD Stock all came with angled manifolds and the center dump was a 4 WD aplication.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
I thought I read that some guys here are running the Corvette 2.5 inch straight dumps with no problems. Dorman makes them new now.
