Old 10-27-2009, 07:02 PM   #1
chockblockjed
chockblockjed's Avatar
california stock exhaust
anyone know the stock configuration of an exhaust system for an 81' C10 short bed with a 350 and standard transmission? i have to visit the CA DMV referee for my engine swap and want to make sure my exhaust is good to go, especially with all the new 2009 cat laws around here.
1981 C10 SWB 350 (in progress) 3 on the Tree "Old Bess"
1996 K3500 Crew Cab 454 4L80E "Family Camper"
2002 GMC 1500 Yukon XL 4WD "Wife's Ride"
chockblockjed is offline   Reply With Quote
Old 10-27-2009, 10:24 PM   #2
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: california stock exhaust
I'm not sure of your configuration, but I'd stop by a muffler shop and see if they can look it up for you. They use a manual that shows the stock exhaust set-ups for all vehicles originally equipped with cats. Worth a try.
78 Big10 454 is offline   Reply With Quote
Old 10-28-2009, 11:58 AM   #3
chockblockjed
The muffler shop I use has two manuals with conflicting info, one says two cats and the other says one, ain't that a shocker. Hoping someone on here remembers their 81' before they started wrenching on it!
Old 10-28-2009, 12:08 PM   #4
menace121978
menace121978's Avatar
1 cat. if you look under your truck you should see where the frame rail on the drivers side was bent to fit the large old school cat in there between the tranny and frame. thats how my '78 and '85 k5 were. 1 cat... smog tube manifolds to a y-pipe to the cat out to a muffler.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-28-2009, 02:40 PM   #5
78 Big10 454
78 Big10 454
Mine was set up the same exact way with one cat wying off to two mufflers/tailpipes. I subsequently changed over to two cats/mufflers in 1980 and have never had a problem with passing smog.
Old 10-28-2009, 09:29 PM   #6
chockblockjed
Thanks! Confirmed y-pipe to one cat. I hope to go to duals as well, but since I have to visit the CA DMV referee for the engine swap and there are some stringent cat laws effective this year, I figure I would go stock for now. Thanks for the input!
Old 10-28-2009, 09:50 PM   #7
78 Big10 454
78 Big10 454
We are at your service!
Old 10-29-2009, 12:18 AM   #8
menace121978
"Dennis the Menace"
Old 11-27-2009, 11:15 PM   #9
Navy Lalor
Navy Lalor's Avatar
dude i am in san diego and swapped out a for a 350 bored .60 over extreme comp cam forged pistons, posi rear 4:11 gears....650 holley carb..then headers straight to cherry bombs thats it ..wo cares california can suck my balls.....keep your stuff registered in another state
if your military
DON'T TREAD ON ME
ACTIVE US NAVY
just a 19 year old kid putting together a winner
Navy Lalor is offline   Reply With Quote
Old 11-28-2009, 12:09 AM   #10
AceX
>130dB Moderator
AceX's Avatar
For those of us who aren't signed up though...
There aren't any new laws pertaining to cats or the quipment in general. They have been the same for a long time. You need the OEM equipment from the donor car/motor or an OEM equivlent. Thy will allow you to run newer style cats and such, but you are not allowed to eliminate any equipment from the system and the ref. knows how to check if its in working order, so don't try and slip past him either.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 11-28-2009, 12:09 AM   #11
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
lmao, its like the man kickin it to the man!
staggerd86c-10 is offline   Reply With Quote
Old 11-28-2009, 12:10 AM   #12
staggerd86c-10
in cali you guys cant run aftermarket straight thru high flow cats? damn that sucks.
Old 11-28-2009, 12:45 AM   #13
chockblockjed
Its done for now. I went stock 2.5 with custom collectors and y pipe into 2.5 oem style cat into single 3" out the side. I get to visit the referee next month and get my sticker for a CA legal motor swap. I have been driving the truck for the past two weeks to work and really love it! It moves without effort and sounds great.
Old 11-28-2009, 01:46 AM   #14
longbedrick
longbedrick's Avatar
I had an '81 K5 Blazer that was all stock. The exhaust manifolds came together at a "Y" then exited through one cat-back and one exhaust pipe. my '76 1/2ton had true dual exhaust with no cat backs and only A.I.R. fittings on the exhaust manifolds. both were California vehicles
longbedrick is offline   Reply With Quote
Old 11-28-2009, 04:05 AM   #15
Malo83
Cruzzzn' Vet
Malo83's Avatar
I'm running a Magnaflow 3" High Flow cat on my 83 with no problems
Malo83 is offline   Reply With Quote
Old 11-28-2009, 09:37 AM   #16
SSC's76
No No
SSC's76's Avatar
The 76 was probably a federal version regular leaded gasoline. Alot of the trucks around here were setup that way to. Anything with that good old unleaded only came with a cat. Needeless to say thats probably the 1st modification my old man did when we moved to colorado back in the early 80's. LOL.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
