10-27-2009, 03:11 PM | #1 |
Bed off from cab!
I am looking at my bed to cab side to side alignment and my bed seems to sit a bit off to one side. not to much but enough I noticed it....
is this common? easy to fix? what are everyones opiniions? |
10-27-2009, 04:37 PM | #2 |
Re: Bed off from cab!
I believe this is pretty common. Both 69's I've owned were not aligned properly. I never worried about it. The bed is just held on by like 6 bolts. You should be able to pull them loose and make the adjustment. Worst case, you might have to drill out a couple of the holes to allow for the adjustment.
Or you can do like I've done, and just drive it... |
10-27-2009, 06:17 PM | #3 |
Pretty common even in later years
10-28-2009, 09:43 PM | #4 |
Sofa King Crazy!!
Hey Vegas, the bed does have some play in it when you loosen the bolts, mine can move from side to side about 1/2 of an inch or so and that should be enough. If the front is moved one way and the back the opposite direction you could get about an inch. Or just wallow the holes a little!!!! Ummm......I think.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 10-28-2009 at 09:44 PM. |
10-28-2009, 10:21 PM | #5 | |
