where to get ford 8.8 u bolts?
I need a set of U bolts for a ford explorer rear end swap, they are 3 1/4 wide instead of the common 3 inch bolts. Jeggs has them for $29 per bolt but I am sure they are availible for less than that. for those who did this swap where did you get yours?
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
Re: where to get ford 8.8 u bolts?
We have ours made here in Houston at a company called Pruits. They make them while you wait. Any size. Most rear end bolts are $20.00 for four with nuts. You may not have a place where you live but their is probably some company close. $29.00 is too high. There are companys that you can imput your dimensions online and they will make them also. Less then that.
You can check NAPA but usually there is a spring shop in most cities if any size that works on truck and rv springs that can make up the U bolts you need if they don't have them in stock. You might also check the 4x4 parts shops as they usually have good supplies of U bolts in stock.
Junk yard. I pick up the drive shafts and U bolts when I get my axles. I've used a set of u bolts that are too narrow in a lowering block kit, you just have to man up and squeeze em together to get it back into the holes on the plate
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
Mine came from the junkyard when i pulled my 8.8. They seem to be in good condition. I dont think I'll end up using them due to I plan on building a 4 link so if you want them you can have them for the shipping cost.
thanks for the offer hotrod but I ordered from sumitt already, all four for $31. they fit a Jeep but are the correct size.
here they are if anyone else needs some http://www.summitracing.com/parts/EXP-50050/
