04-16-2003, 04:51 AM | #1 |
Right turn Clyde
GM Part #s
GM Vehicle Care Products:
1050002 Top Engine Cleaner $ 4.13 1052196 Lubriplate Lubricant $ 5.43 1052271 80w90 Axle Lubricant $ 5.42 1052358 Positraction Additive $ 5.34 1052367 EOS/Assembly Lube $ 5.34 1052627 Heat Valve Lubricant $ 5.77 12345104 Fuel System Trtmt. 20oz $14.03 12345347 Hydraulic Clutch Fluid $ 7.71 12345515 Fuel System Trtmt. 12oz $ 9.37 12345586 Cooling Sys. Fast Flush $ 3.78 12345837 Auto Trans. Conditioner $ 4.93 12345866 Power Stg. Fluid 16oz $ 6.81 12345867 Power Stg. Fluid 32oz $10.95 12346290 DexCool Antifreeze $11.69 12377916 Synchromesh Trans Fluid $ 8.32 12377967 DOT 3 Brake Fluid $ 4.97 12378508 Auto Trac Fluid $ 4.52 12378470 Dexron III/Mercon ATF $ 2.77 http://chevygear.home.attbi.com/Vcare.htm I havent bought anything from this company, just thought someone would like the gm part #s For some reason the link is adding something on the end of the address, it does work
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI Last edited by MylilBowTie; 04-16-2003 at 06:22 AM. |
04-16-2003, 05:52 AM | #2 |
Thanks for the try but that link is a 404.
It does look like good stuff on your list. |
04-16-2003, 06:25 AM | #3 |
Right turn Clyde
Delete the </a> it will work. Im not real sure how to type up html so I just used the buttons and one of them is messed up possibly?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
04-16-2003, 06:35 AM | #4 |
04-16-2003, 06:53 AM | #5 |
Much better MSL....
Thanks to both of you! Mike |
04-16-2003, 07:02 AM | #6 |
No problem glad to help out.
