Old 10-27-2009, 11:06 PM   #1976
tiggamonsta
tiggamonsta's Avatar
Re: Project Vitamin C-10
Originally Posted by jgh64pkup View Post
hey alan the pics of your hood got me thinking
i want to build my own fiberglass hood and use the inside steel bracing from the stock hood
i dont know if it would work but i think it would be better than a aftermarket one
what do you think
Check out this forum for fiberglass stuff. http://www.fiberglassforums.com/ There is some really cool work being done. And if you want to see some really over the top work read this thread. http://www.fiberglassforums.com/showthread.php?t=5267 If I remember correctly you need to join to see the images.
tiggamonsta is offline   Reply With Quote
Old 10-27-2009, 11:16 PM   #1977
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
thanks i just joined now im waiting to be approved
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 10-28-2009, 10:33 AM   #1978
Strodder
Daring to be Different
Strodder's Avatar
Originally Posted by Denver64 View Post
Wow! It has taken me about a month of pretty regular reading to get to this point. Awesome build Alan!!! This should be a must read for anyone that is going to do a full frame off resto. It really goes to show that a project of this magnitude becomes part of your life and yet there is a lot of life going on around our builds and there isn't always time to work on our trucks. Also it's crazy that just reading these build threads makes me feel like I know a lot of you guys. It is so easy to get sucked into this site because it's more than just nuts and bolts in these threads, there's a lot of blood, sweat, and tears. Kudos to all of you and especially Alan for the great reading and all the valuable tips and information!
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-29-2009, 11:29 PM   #1979
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Thanks for the compliments with the well written post. It keeps me motivated knowing what I do either right or wrong helps people.
Nice links.
Got the Mar-K inner bedside patches installed on one bedside plus I also did a couple other patches. The patches were great and are one of the easiest patch panels you will ever do.
Did some measuring to determine where to make my cut and got the patch clamped in place.
Installed the wheel house to make sure everything is lined up. With it clamped in place will help hold everything in place.
Completed
Had to make and replace the short angle. I made it out of some good metal that I just cut out for the patch. That way I would have a good square hole to go in the corner. It's hard to get a drill in the corner later when I test fit everything.
I used some old metal from a scrap door to make a patch.
I reversed the bend.
Held it in place with self tapping screws to create a template.
Getting it lined up.
I knotched mine here. Others will do it differently, but worked well for me. There was too much going on in one location. The lap, corner and bolt hole were all too close together. I chose to space things out a little. There is a lower bolt hole to use for alignment.
more on next post
Alan's Classic is offline   Reply With Quote
Old 10-29-2009, 11:30 PM   #1980
Alan's Classic
Done welding just need to grind.
Old 10-29-2009, 11:40 PM   #1981
scotts62
One day...
scotts62's Avatar
Nice work Alan! I have a couple panels to patch i will just send them on over since you already have your tools out and warmed up
Scott
93 crew cab build
Project 62
Old 10-29-2009, 11:40 PM   #1982
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
and of course it looks perfect
alan you make this look so easy
Gage
Old 10-30-2009, 12:10 AM   #1983
daverod
SSN 706
daverod's Avatar
Very nice.
daverod is offline   Reply With Quote
Old 10-30-2009, 12:17 AM   #1984
Alan's Classic
I had to knock the rust off of the tools. It's been a while since I got anything done to it.
Thanks. I always remember my first years as a body man. Still got a lot to learn.
I'm thinking about cutting my own wood for the bed. The only thing I haven't built on this truck is the rearend and trans. I might pay someone to install the windshield just because of the breakage factor. I think it will still classify as home built.
Old 10-30-2009, 07:33 AM   #1985
4dranch
Shloooooong bed member #2
4dranch's Avatar
very nice work Alan
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 10-30-2009, 09:52 AM   #1986
aggie91
I'm just glad to be here!
aggie91's Avatar
OH, I do not think anyone will argue about yours being homebuilt.
There are somethings that I let the more qualified people in know do for my stuff. Trans work, Engine short block machine work and assembly, rear gear set up, seat upholstery, winsheild install (for the same reason you mentioned)...you know, the things that I don't have the correct tools for...
Looking good, ALAN!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-30-2009, 10:20 AM   #1987
70 Suburban
Rods
This is and has been an amazing adventure and undertaking. Thanks for the effort you put into yours. Its helps us all feel that we can do more.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 10-30-2009, 10:51 AM   #1988
MacAttack
283 Drama Queen
MacAttack's Avatar
Hands down, Alan - best build thread so far. Detail is incredible and it's easy to see the care taken in thinking the process out. Thanks again for the effort.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 10-30-2009, 11:16 AM   #1989
Strodder
Strodder's Avatar
Great job Allan. You do make it look easy, but we know it's not.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-30-2009, 12:27 PM   #1990
1964C10
1964C10's Avatar
I second everyone above, great job, and yes you make it look so easy! Looking back I wish I would have used patch panels myself instead of welding in just an bottom angle but no dineros lol. And as always many thanks for the pictures and write up.
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 10-30-2009, 05:16 PM   #1991
Alan's Classic
Originally Posted by 4dranch View Post
very nice work Alan
Thanks David!!
Looking good, ALAN!
I appreciate it!!. I forgot about the upholstry. Plan is for black leather wrap with orange and black houndstooth inset.
Mac.
Thanks Mac!! Yeah, I do have a thinking problem.
Amen brother!! Patience is a must with doing body work.
No matter your range of experience, there will always be things you wish you should have done differently. I have several things on my mind. There will be more once I get all of the systems working.
I checked on line with homedepot for wood. A 1X8 red oak is $4.10/linear foot. I figured the cost with tax to be around $350. There are only 2 boards of the 10 runs that a 1X6 wood work, so I just figured all 10 runs at 8" wide. I will contact some cabinet shops to see what their cost would be. If there isn't much difference in price why not just buy them pre made, other than just the satisfaction of doing it yourself.
Old 10-30-2009, 06:03 PM   #1992
shortbed70
shortbed70's Avatar
Yes sir thats what I call progress... Good work man.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-30-2009, 08:20 PM   #1993
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Alan your my hero, when I grow up I wanna be just like you. LOL
Keep it up man I enjoy reading about all your good tips.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-31-2009, 09:20 AM   #1994
tiggamonsta
... If there isn't much difference in price why not just buy them pre made, other than just the satisfaction of doing it yourself.
Choose a type of wood that is not available pre-made. Then it makes the decision easy, and the truck more custom.
Old 11-01-2009, 07:45 PM   #1995
Alan's Classic
You might want to check with my wife before you say that. She can tell you all of my flaws.
Great idea. I found Peach State Lumber that has a lot of different kinds of wood. Here is their Web site
Finally got around to cutting up a tree that my dad cut down in the spring. Everyone needs a great neighbor like Shannon. I told him I was splitting wood and he was over in no time. Good thing I hand a rand handed axe. Had to get an action shot.
I found a new sand blaster/powder coater 8 miles from the house. Anyone in the area needs to check him out. He has a great place with great equipment. Custom Powder Worx ask for Ervin @ 404-216-4230. He has a big oven to powder coat frames. Tell him I referred you. I get nothing off of it. I asked him if it would be ok if I put his info here, since he doesn't advertise. He is about 5 miles off exit 27 on I-575.
Old 11-01-2009, 10:42 PM   #1996
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
Still watching and checking in daily... The 51 and I are looking for a little adventure... Thinking about taking a little ride up when things slow down a bit..(nothing like inviting myself up!)
Keep up the great work, I have learned a lot from your thread..
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 11-02-2009, 12:02 AM   #1997
tiggamonsta
I vote for the Bubinga under the exotics. It has some really nice grain. Of course that is without knowing the cost.
At the Texas Classic Car Show in Austin this weekend a guy had an F100 with a Granite bed. It was definitely different. Unfortunately it was in the last row we looked at and everyone was bugging me to leave, so I did not get a photo.
Old 11-02-2009, 12:04 AM   #1998
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
GRANITE!!!
that must have been heavy
Gage
Old 11-02-2009, 12:08 AM   #1999
jsmithbm
jsmithbm's Avatar
i need some firewood, i will be up there soon to pickup some shannon. LOL hope all is well up there! Sorry i havent gave ya'll a shout in a while been busy at work.
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 11-03-2009, 12:20 AM   #2000
Alan's Classic
Thanks Taylor, invite yourself anytime. Lookin forward to seeing the 51.
I didn't call them today, I hope tomorrow. I'll post up a few prices once I get them.
GRANITE!!!
I'm just as guilty for not calling.
I forgot to mention before that I left my hood and grill at the sand blaster
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
