Old 10-29-2009, 08:40 PM   #1
Daniellane
8 lug crew cab 1 ton
how do i convert the front to 5 lug suspension from a burb? need to know quickly
Daniellane is offline   Reply With Quote
Old 10-30-2009, 12:28 AM   #2
pig rig
pig rig's Avatar
Re: 8 lug crew cab 1 ton
change the a arms spindels rotors and calipers but the crossmember is the same
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 10-30-2009, 01:38 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Upper ball joints are factory rivited in. Replacements are bolted in. 3/4 ton and 1 ton ball joints are the same. 1/2 ton ball joints are a smaller diameter but have the same bolt pattern as the 3/4 & 1 tons so they can easily be switched out.
The lower ball joints are pressed in and are of different diameters where they mount into the lower control arms. Again, 3/4 & 1 ton lower ball joints are the same but the lowers are smaller so you would have to swap out the following parts....
UPPER BALL JOINTS
SPLINDLES
LOWER CONTROL ARMS W/BALL JOINTS
SPRINGS
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-30-2009, 01:25 PM   #4
Daniellane
so therefore basically everything is bolt in? would i have to buy anything? i have a complete 1/2 ton burb for parts
Old 10-30-2009, 02:49 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
ECE (Early Classic Enterprises) sells a "conversion" 2.5" drop spindle that will use the 1/2 ton rotors and calipers off your 'burb.
They list them as C20 to C10 conversion spindles,... but the C20 balljoints are the same as the C30 balljoints,... so everything will bolt onto your original ball joints and tie rod ends.
No need to swap a-arms or anything else,... other than from the spindles out.
Keith
Convert to disc brakes.
Old 10-30-2009, 02:50 PM   #6
lolife99
lolife99's Avatar
What do you plan on doing with the rearend to make it 5-lug?
Keith
Old 10-30-2009, 02:57 PM   #7
BGRAFX
the burb should have a 5lug rearend on it, just swap that too.
BGRAFX is offline   Reply With Quote
Old 10-30-2009, 04:11 PM   #8
Daniellane
is that only for 60-72's? and yeah im just gonna swap the rears
Old 10-30-2009, 04:44 PM   #9
lolife99
lolife99's Avatar
All years.
http://www.earlyclassic.com/catalog.aspx
QUOTE from ECE:
Looking to convert your ¾ ton Truck to ½ ton front suspension? We are proud to introduce the only C-20 to C-10 2½" Drop Spindles available on the market. (disc brakes required).
Over the years, we’ve had many customers with C-20 8-lug Trucks that would like to convert over to the better riding C-10 suspension and change their wheels to either a 5-lug or 6-lug bolt pattern. These new Conversion Spindles allow you to upgrade to C-10 front disc brakes on the ’60-’70 model Trucks, and give you the option of 2½" front Drop Spindles for the same price without having to change your tie rods and ball joints.
Several options are available to change the rear suspension and axle as well, and our technical support staff is more than happy to explain the different methods and choices available for each Truck year and model. Give us a call, we’re here to help
Keith
Old 10-30-2009, 04:52 PM   #10
Daniellane
ah i see. well im a little low on cash fund and i got the spare surburban and i was hoping i could just switch all the stuff over in a few days work
Old 10-30-2009, 05:06 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
No reason why you can't do it that way. Pull the A-arms along with shafts, or swap the entire crossmember assembly.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-30-2009, 05:12 PM   #12
Daniellane
entire crossmember it is. n2trux if ya ever wanna sell that rramjet truck. i got dibbs.
Old 10-30-2009, 06:34 PM   #13
lolife99
lolife99's Avatar
Don't pull the crossmember unless you want to mess with the engine mounts.
All you need to do is change everything from the a-arms out.
I suggested spindles for ease,... not money reasons.
Since you want to use all of your parts, without spending any cash,... leave your original crossmember, and change everything else.
Keith
Old 10-30-2009, 06:54 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Don't pull the crossmember unless you want to mess with the engine mounts. ....
Good point.
Daniellane- Everything has a price, but as they saw if you have to ask....
Articles-
"Refining Sierra"
Old 10-30-2009, 07:25 PM   #15
Daniellane
ha. its a bad []-body. so whatcha think a 502 vortec 8100 is worth? i got offered one for my crew project
Old 10-30-2009, 10:00 PM   #16
pig rig
pig rig's Avatar
I belive that the 1/2T rear wont bolt in the place of the 1T because of the rear spring mounts?
on the crew cabs the springs are wider then that of a std cab 1/2T (or the other way around) so I dont know if that holds true for the 1T std cab trucks
you may need to swap spring mounts
