Old 10-31-2009, 11:38 AM   #1076
SCOTI
SCOTI's Avatar
Re: Daverods project 66
Originally Posted by Strodder View Post
Dave you got me thinking last night. You can also raise the front portion of the frame in front of the cab. Like you would do in the rear. It would raise your engine too, so you can't go too high. It would for sure get your 20s on and lay frame. You would also have to drop the front portion of the frame in front of the cross member to mount the sheet metal and bumper. Lots of work, and the cheapest way to go.
Watahyahknow's idea is good too, but looks like it would be expensive. Do you have a link to there web site?
You've just described a frame 'Z' where the frame stub is cut-off & re-attached higher vs. the original rails. If you've got more time/talent vs. money, it's worth doing. If your lacking either, Nathans Dropmember does the same thing & fixes many 'compromises' that people experience when notching a stock crossmember (and the extra work for the radiator core support when doing a 'Z').
I've done the crossmember notch but it doesn't give you much for the work. To combine a c.member notch + frame 'Z' is just extra work. Skip the c.member notch & raise the rails up more when doing the 'Z' (I realize the OP has already done the c.member notch).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-31-2009, 11:45 AM   #1077
Strodder
Daring to be Different
Strodder's Avatar
I know it's called "Z"ing the frame. Not everybody knows that term. I think Dave has the talent to do it. It's a lot of work, and scary to do.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-31-2009, 12:11 PM   #1078
SCOTI
SCOTI's Avatar
I figured as much but wanted to insert the 'term' w/the description for those not familiar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2009, 12:13 PM   #1079
Strodder
Strodder's Avatar
You described it better
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-31-2009, 12:22 PM   #1080
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
see dave i told you that you need to z the frame
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 10-31-2009, 12:24 PM   #1081
watahyahknow
watahyahknow's Avatar
the Z ing makes for a lot of sheetmetal adaptations , another way would be to channel or floor the body over the frame wish keeps the frame stock but limits headroom in the cab.
channeling is just wat i says two sheetmetal channels made in the floor to drop the whole lot over the frame it does leave a big speedbump in the middle of the floor in the cab and the stock carpet whont fit no more
the space to the roof stays the same
the biggest challenge is to rethink the sheetmetal in front of the cab (innerfenders radiatorsupport and all that lot need to be shortened and mounted lower ) and making sure the stuff hanging from the bulkhead whont hit the engine and the top of the engine whont hit the hood .
flooring is basicly cutting the floor and most of the bulkhead and some of the rearwall of the cab trimming it the amount you want to go lower and reweld it in , this leaves the floor stock looking but with a step in the doorframe and less room inside the cab floor to roof
they do this a lot when they want to drag the body to bottom of the doors (they remove all sheetmetal below it )
you can still fit the stock carpet back in after some trimming , the rest of the sheetmetal lowering stays the same as with channeling the clearance problems too
the bed can be either floored too or lowered by shortening the mounts and cutting holes above the pumpkin and rearframe above the axle
in my eyes flooring looks the best but is the most work and the porterbuild dropmember is the easest safing a LOT of work to make the rest fit
on duallyscene.com they have a lot of pictures of these adaptations though they mostly use 77 and up trucks , there laying frame with 22 inch truckrims under there pickups
sorry stroddler missed you request there for a moment heres the link to the dropmember http://www.porterbuiltstreetrods.com hes building a new website tough
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-31-2009, 02:31 PM   #1082
Strodder
Strodder's Avatar
There is so many ways to get this done. You just have to pick the one that you can do, or can afford.
Thanks for the link watahyahknow
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-31-2009, 03:16 PM   #1083
daverod
SSN 706
daverod's Avatar
Life is so simple. All I need is more money. Couple grand. I do like the drop member. Wonder what I have to do to keep my arms. Don't really want to buy arms and a member.
daverod is offline   Reply With Quote
Old 10-31-2009, 04:34 PM   #1084
SCOTI
SCOTI's Avatar
Originally Posted by daverod View Post
Life is so simple. All I need is more money. Couple grand. Suck "I can fix that for ya for a couple grand". I do like the drop member. Wonder what I have to do to keep my arms. Don't really want to buy arms and a member.
You can re-use the stock arms w/the original DM. The later versions can use OE arms but they'll need to be from a 73-87.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2009, 05:42 PM   #1085
daverod
SSN 706
daverod's Avatar
The arms I have now are off a 71. But I'm going to change the control arms and ball joints to the 73 type. Do they still sale the orginal DM?
Old 10-31-2009, 05:42 PM   #1086
daverod
SSN 706
daverod's Avatar
When ?
Old 10-31-2009, 05:46 PM   #1087
SCOTI
SCOTI's Avatar
You could check w/Nathan on the V1 DM. I know they pop up 'used' from time to time as some have upgraded to his newer versions. If you're upgrading to 73-up arms/BJ's, the newer version (V3) will work for you.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2009, 06:44 PM   #1088
watahyahknow
the cheapest way offcourse would be living with the fact it isnt laying frame ............or mount smaller rims
Old 11-01-2009, 01:26 PM   #1089
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Post 1056
When ?
Gage
Old 11-01-2009, 07:15 PM   #1090
daverod
SSN 706
daverod's Avatar
And I could use that money saved by not lying frame to buy some cool wheels and tires. bDo I really care if my frame is a couple inches high:? I'll lay frame in the back. The outside diameter of thew tires I have now is about 30" My spindle is at 12" so my frame will be about 3" in the air. If I use a tire like 265 35z r20 they are only 27" in diameter.
Old 11-01-2009, 09:59 PM   #1091
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
you know, even if you dont lay frame, I will be. haha
You could always body drop it to look like it is.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-02-2009, 02:52 PM   #1092
watahyahknow
http://67-72chevytrucks.com/vboard/s...43#post3598643
dropmember installed on a 69
Old 11-02-2009, 07:51 PM   #1093
daverod
SSN 706
daverod's Avatar
They are nice.
Old 11-04-2009, 10:11 AM   #1094
daverod
SSN 706
daverod's Avatar
[img]http://www.*****************/files/P-47-63-87-Raised-Crossmember-Kit.jpg[/img] They make it to easy. Does take all the headache away. Rack and pinion and your done. Then I could be like Ruff.
Old 11-04-2009, 10:27 AM   #1095
61TWUK
61TWUK's Avatar
whose kit is that?
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 11-04-2009, 11:16 AM   #1096
daverod
SSN 706
daverod's Avatar
Originally Posted by 61TWUK View Post
whose kit is that?
It was on http://www.*****************/front_page$ 1199. I think Porterbuilt makes one too. I can't get to his site though.
Old 11-04-2009, 12:47 PM   #1097
watahyahknow
it actually looks exactly like the porterbuild one
Old 11-04-2009, 09:18 PM   #1098
daverod
SSN 706
daverod's Avatar
Took my fenders off my 64, ordered some bottom patches. Put my body on my frame. Sat in it went up and down.laid some frame.
Old 11-04-2009, 09:19 PM   #1099
daverod
SSN 706
daverod's Avatar
Even my sled lays frame
Old 11-04-2009, 10:17 PM   #1100
ruffrida2005
That kit is based off of Nates kit, but it has a bunch of stuff done diffrent and better then Nates. Mostly less welded parts and better motor mounts.
You still couldn't be like me Dave I have the P-51 kit and that's the P-47
Paul
