Old 10-30-2009, 02:42 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
same cam or bigger?
almost sure i have a flat lobe on my cam, so im going to yank it and probably replace it.
here is what i have now
http://www.jegs.com/i/Comp+Cams/249/12-235-2/10002/-1
head
http://www.jegs.com/i/GM+Performance...58060/10002/-1
GM Performance Parts Cast Iron Vortec SBC Head
original 48k mile 350 motor.
original qjet
hei, with super coil
411 rear end
th350 with shift kit and th400 converter
gear vendor od.
go bigger with the cam? same one?
i need more torque.
i need more torq.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 10-30-2009, 05:04 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: same cam or bigger?
Well, heck, why replace it with the same thing? GO BIGGER, DUDE! Set it up so it won't idle below about 4000 RPM! Ok, maybe not... I had a pretty radical cam in mine and it was actually very driveable. With the stick shift, the only thing I had to do was clutch in a little sooner when slowing down or it would start to buck back and forth, but that was below about 800 RPM.
Cams these days I'm convinced are just more tolerable than they used to be. Let us know the outcome. I'm waiting to hear about pulling your trailer at 65 at half throttle up the side of a mountain... Good luck!
69GMCLonghorn is offline   Reply With Quote
Old 10-31-2009, 10:39 AM   #3
mtdave2
mtdave2's Avatar
man i hope you are right...ugh
69 k10 Suburban
Old 10-31-2009, 12:25 PM   #4
2tons of fun
you ansewerd you own question, you said you need more.........
2tons of fun is offline   Reply With Quote
Old 11-01-2009, 11:00 AM   #5
mtdave2
mtdave2's Avatar
well the one i have now isnt running right. it may be enough but, ill prob do something else
69 k10 Suburban
Old 11-01-2009, 11:43 AM   #6
dnd1978
dnd1978's Avatar
I’m having the same problem with my motor. I’m debating on rebuilding my motor with a roller cam instead of a flat tap cam. It would help with flat lobes but it was cost a little more. I think it would probably be worth it. What you think?
dnd1978 is offline   Reply With Quote
