#26 |
Used to have a truck
You need gears. 4.57's or at least 4.30's . If you have stock 3.73's or worse you'd have the equivalent to 2.73's or thereabouts in a passenger car. SUCK ASS GEARING !!!!!
Dont get me wrong. Hi gears have their place. If you want good gas mileage ... buy a Honda . Use the truck for what God intended. And that would be hauling ass!
No truck :-( |
#27 |
72 Cheyenne
I would also say a higher stall, I have a 3000 stall with 3.55 gears in mine and I have to actually try NOT to burn out at stoplights but I'll admit it's fun when it does he he!! I have to really be carefull, it spins into second too, and it's an auto Tranny!
#28 |
Stuff in a 502HO with a 3.07 Posi--smoke without power braking.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#29 |
Damn, that's another problem I forgot about: a posi diff. So, I have posi-traction, big tires, low HP, 3/4 ton drivetrain, TH-400 tranny, ALL WORKING AGAINST ME!!
EDIT: The only thing I've got going for me is my 4.57 gears ![]() ANOTHER EDIT: I'm going on the assumption that it's posi-traction, but it's a Corporate 10-bolt, which is the same as an Eaton, right? In that case it could very well be a locker? The option listed on the options sheet says "NO-SPIN REAR AXLE". Hmmm, I have no freaking clue what I have... ![]() YET ANOTHER EDIT: Ok, after reading about the characteristics of lockers vs. posi vs. open etc., I'm thinking it might be an Eaton locker, because the tires do make that "chirping around the corners". Yes, I know, not scientific analysis, but it seems most likely. Last edited by 68CST327; 04-14-2003 at 10:41 PM. |
#30 |
I've tried to power break too and no go. I can mash it from a stand still and leave a blackie for a at least a city block, but I can't power break. The 402 is makin about 425hp and 550ft.lbs. of torque, I don't think power is the problem. I can't find the happy medium, either I push the truck b/c breaks aren't pressed enough or they lock up and non of the wheels turn. I am running a stock TH400 and 3.54 gears and I figure a higher stall will do the trick.
#31 | |
A good way to tell if you have a locker in that eaton is to turn the truck off, put it in neutral and grab your rear driveshaft. If you can rotate it 30 degrees or so one way or another then you have a locker. If you had that much slop with an open rear end the thing would self destruct. With the locker you'll have that much slop between the cogs of the locker unit. If you notice when you are going down the road and you let of the gas quickly it will "clunk" a bit as the lockers cogs shift into their coast mode. Give it gas again and it'll clunk the other way. You just need more power ....or a higher stall converter...or both .
No truck :-( |
#32 | |
Edit: While doing this I also burned thru an 1/8th tank of gas. Also, I let off the gas about 5500 rpm, I'm afraid to rev it higher than that. I heard that the redling is about 6 grand on a 350. I know I sound like an idiot doing this, I just want to explore my truck. In my normal driving, I never ever take it over 3 grand. I usually try to keep it under 2.5. I have 3.73 gears, or at least thats what the p/o told me. Originally 4.10's but were swapped, now speedo is off so I assume he's right.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 04-15-2003 at 12:31 AM. |
#33 |
yea..thats one bad mamajama you have there...ever feel like racing??????..lets see if I go to kansas to pick up a new engine..its not that much further to Ohio...lol
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#34 |
Registered Cruiser
I don't know what you're complaining about. I wish my truck hooked up as good as yours. I've got 275/60's on the back of mine, and they'll go up in smoke. I wish I could get it to bite better. Everyones been talking about horsepower. It's torque you need to spin tires.
I intend to live forever. So far, so good. |
#35 | |
![]() Now I'm gonna have to go out tomorrow (if it's not still raining) and check the slop in the driveshaft. |
#36 | |
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#37 |
can someone explain how a power brake is done. Thanks ed ke6bnl So.Calif.
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
#38 |
Put your tranny in 1st gear, hold down the brakes while you press the accelerator, then when the rpm's are high enough, you let off the brake and hopefully the tires break loose.
I think that's the simplified way of doing it; I've seen some people that have really good brake control and are able to let off the brakes just long enough to get the rear tires spinning, then tap on the brakes again to stop the vehicle from moving, but have the rear tires keep spinning. This is all for an automatic transmission; if you have a manual, just dump the clutch ![]() |
#39 |
Thanks for the explanation. My boys 70 sb will easily smoke the tires without any help. I know from the $175 ticket he got because it was hard not to cherp the tires. He now carries 4 five gallon jugs of water tied to the back of the bed of the truck for better traction. That was with 275x60x15 tires 3.73 gears. Ed kebnl So. Calif.
#40 |
My truck will spin the street tires a long ways.
#41 |
Spank 'em if you got 'em!
Stroker, is that from that video?
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
#42 |
Long Knight, yeah that's from the video on my website. That was before I got nitrous, I will get some more video soon with the nitrous. It will spin the street tires in high gear now.
#43 |
![]() Join Date: Dec 2001
I spun my tires yesterday and I thought the engine was about to blow. Maybe I should wait till I rebuild mine before I try anything like some of you.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#44 |
Seasonal Poster
I've managed to get the power braking routine down quite well, as you may see in my Avatar
1. Put right heel on brake pedal. 2. Right toe on gas 3. Left foot on clutch 4. Give'r some gas as you let off the clutch, just like you are trying to take off really fast, but don't dump the clutch. 5. As the tires spin, move your left foot to the brake pedal 6. Hold until desired tire smoke level is acheived 7. Release brake, mash gas, lay rubber!
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
#45 |
I am currently unable to play video on my computer, but I remember Slammed67 showing me the clips of Stroker383 awhile back! Outragious!
Hey, Greasemonkey, better to screw something up in the motor now than after the rebuilt, right? LOL If you do screw something up, it will just move the rebuild date up a little! Woohoo!
#46 |
I wouldn't mind that, but I am flat broke right now. If I screw it up now, I am out of a ride. Hopefully I can find a job so I can rebuild it this fall. I plan to buy a cheap crate engine so I can still drive the truck while the rebuild is going on.
#47 |
ready for reassembly
tires make all the difference in the world too! I used to have 32x11.5 AT's(very little tread left) on my truck, and I could spin the tires pretty easily. Now I have a new 31x10.5 with a very aggresive tread, and i'm lucky if I can kick them out around corners
The same was true for my jeep i used to have. With the bald tires it would spin with ease....as soon as I put the aggresive tires(same brand as truck's) it wouldn't even chirp! i'm pretty sure my truck has the high rear end though.....not a lot of bottom end torque, but once it's going it accelerates pretty well Jason ![]()
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
