Old 10-30-2009, 09:26 AM   #1
Silence86
Silence86's Avatar
heater problems..help
ok so on my 86, the heater only really works when im driving...when i come to a light, kinda stops. this really sucks cause this morning i needed to use my defrost and had to roll with the window down freezing my a off...help please
Silence86 is offline   Reply With Quote
Old 10-30-2009, 07:17 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: heater problems..help
the fan motor stops or the temperature of the air coming out changes?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-01-2009, 10:15 PM   #3
Silence86
Silence86's Avatar
the fan motor doesnt completely stop just slows down alot
Old 11-01-2009, 11:00 PM   #4
old Rusty C10
sounds like either there is a wiring issue or there is an issue with a connection id start there and work my way back to a blower fan relay, as long as the alternator is good and there is no charging issue where the voltage drops at idle so that it doesnt get enough juice to spin the blower motor
Bob
I hate cancer!!
Old 11-01-2009, 11:01 PM   #5
Silence86
Silence86's Avatar
ill check first thing tomorro morning thanks
Old 11-02-2009, 03:02 AM   #6
TravisMartin
Curmudgeon of Poor Means
Sounds to me like the fan isn't running at all, or maybe just on low...you're getting some air when driving from the wind pushing it in.
I'm assuming you've already checked the fuse?
Check the blower resistor and its plug; they're bad about rusting and overheating and making poor connection. It'll be about a five wire plug onto a diamond shaped gizmo (the blower resistor) mounted to the a/c suitcase over by the right hood hinge. The resistor is held into the suitcase with two hex head self tapping screws. Take it out of the suitcase and inspect it...there are three resistors on the part if I recall. If any of them is broken or if any of them has broken loose from its terminal, you need to replace the assembly; they're made of nichrome wire and you can't solder them. Make sure the terminals are clean and making good contact with the connector.
If you still have problems, it's probably the dash switch. Post your progress and we'll help.
Travis
TravisMartin is offline   Reply With Quote
